Results 1 to 10 of 18
Thread: s2a and s3 compatability
    Sep 2010
    underneath the stars
    i have the opportunity to buy a s3 swb and a s2a swb both are need of repair badly. my intentions are to mainly do the s2a. it has a good firewall and chassis. it does how ever need most panels need replacing. will i have any problems with this or will they all line up perfectly? i suppose what i am really asking is what problems will i have putting s3 body panels(excluding roof and tailgate) on a s2a? also what differences are there in the engine and gearbox and diffs aswell?
    papa smurf
    small stuff really but nothing that prevents you from swapping major and most of the minor sub asemblies over. IE you can bolt one gearbox in the place of the other and you can unbolt the tcase from one and bolt it onto the other But you cant take the lay shaft out of one gearbox and put it in the other (and even then sometimes you can) without doing some mods.
    JDNSW's Avatar
    Virtually everything on 2a and 3 are interchangeable even if only as complete assemblies. There are a few minor problems - for example the windscreens are not interchangeable because the hinges are different - but the glass is interchangeable, or you could modify the bulkhead to take S3 hinges.
    Transfer cases are fully interchangeable, gearboxes are interchangeable except the clutch piping is different, and so on. Except for the bulkhead, almost all the body is either identical or interchangeable panel by panel. Front and rear axles are the same or interchangeable, except that the 109 went to the salisbury rear in late production. Note that there was a gradual change from British to Unified threads throughout 2a production, with metric threads introduced in late S3 production.
    Sep 2010
    so s3 and s2a axles are the same?
    near enough that they interchange.
    Oct 2010
    Buderim, QLD
    Smile S2a to S3 interchangeabiity
    Hi, first time post and first time project Landy owner... I'm trying to rebuild a '64 S2A diesel but I'm having trouble trying to get a starter motor and replace the 6v generator with a 12v alternator. Both are unservicable and to try and rebuild them would be a waste of time, if I want to run a modern 12v battery and electrical. Can I use late model S3 parts for this or even county bits?
    Cheers.
    '64 S2A Diesel 88" for me , the kids and the dog,
    '04 Disco 2 for the missus.
    Nov 2006
    Wollongong NSW
    If it's a diesel you might be getting confused. It should be 12v.
    has it got 2 6v batteries ? I never seen a 6v diesel. Any S3 alternator will do..
    drifter Guest
    Starter Motor and Alternator available via KB Classic Parts in QLD. He was a Lucas man for over 40 years - knows the stuff backwards. I was speaking with him last night about the same stuff. Details: Kevin Baker ph 07 54944221
    All Land Rovers are 12V. The original generator is very cheap and easy to rebuild. The starter from a 200Tdi fits and works well. These are quite affordable second hand
    Aaron.
    JDNSW's Avatar
    As above. The early Series 2a diesels used two six volt batteries in series to get sufficient cranking current in the available space - one under the bonnet and one under the seat.
    Unless trying for originality I would use a single 12v battery in either position, and change to negative earth while at it. The generator, while probably repairable, I would replace with an alternator - Series 3 or several others would fit easily using Series 3 brackets.
    The starter is almost certainly repairable cheaply, but the 200Tdi starter suggested is more readily serviced, lighter, and generally a better option.
