Results 1 to 10 of 18
Thread: One day in...
    South Australia
    One day in...
    Finally picked up the P38 on Friday, and must admit we're wrapped (yes SWMBO is impressed too). It's more than met it's main purpose of providing more room (not hard when our daily had been a Suzuki Swift - lol) and has done so in style.
    Also fitted a set of late vogue 18" wheels that I picked up via Triumph Rover Spares. I got talked out of buying later L322 wheels in favour of correct 18" style rims - and I'm glad I did, as no issue with adaptor rings or different bolts, plus they really suit it. (will post some pics later)
    So far everything has been working as it should, and we have found no major gremlins - well none except one - It has a bit of a shake at about 80kmh.
    Now when I say a 'bit of a shake' it actually starts to oscillate when it hits a bump - a tad worrying - but also something that I have experienced before. Accelerating through the shake remedies the issue - it stops at about 90k/h. I have a feeling that a suspension bush may be shot, as when I've come across this before, the culprit has been loose suspension joints. BUT.... (and here's the thing...) The suspension did not seem loose in any way (I did a quick top to bottom + side to side check on the front).
    So, as a next stop, I decided to measure the geometry and found that the alignment was waaaaaay out - some 15mm toe-in, which equates to about 1.8 degrees. The RAVE CD tells me it should be at about 0.6-1.8mm toe OUT. I'm going to address this tomorrow morning, before we go on a trip to Victor Harbour, and see how things are. Worst case scenario - it's a slow drive home at 70k/h. Worst, worst case scenario, the RAA man takes us home (or we and up in a ditch). LOL
    Other than having to deal with this hopefully minor issue, I've ordered an ipod adaptor from incaripod, and done a bit of digging into rooftop tents and stuff like Drifta kitchens (they seem pretty cool). Managed to pick up a cheap (badly listed on ebay) petrol stove (dual burner version of a coleman stove I used to have in my old VW Kombi), and have been looking about for other camping stuff. We've decided to eventually get it kitted out for some family holidays and go 'bush'. (with cash that I could have spent on restoring our '62 Kombi - which was originally supposed to be the family holiday wagon - but such is life - lol)
    So, one day in, we both love it. Hopefully the shaking issue is a minor one, but at any rate I'm going to book it into an interim service at Triumph Rover Spares, so will get them to give it the once-over.
    I'm a little ****ed that I did not manage to pick the shaking issue on the test drive, the steering did seem to track a little, but the brakes pulled up straight, and it took off in a straight line, so I figured it could not be too much, only thing I did not get to do was take it to the freeway (Adelaide is only small and has no major fast roads).
    Either adjusting it will solve the issue, or I'm in for my first instalment in P38 ownership
    Mick.
    Mar 2009
    Melton West, Victoria
    Congrats on the P38 - should be a nice step up from a zook First thing I'd check re your steering would be front tyre pressure. It's common for tyre fitters etc to overinflate them. RAVE says 28psi for the fronts (back is much higher) - if its much higher than 28psi you can get weird steering/tracking issues developing. I'd get all the tyres checked for balance and a wheel alignment done too - easy fix maybe.
    May you continue to be very happy with your purchase!!
    38psi rear/28psi front is a good compromise. It also serves to slightly preload the viscous coupling due to slight differences f/r in tyre circumfrences.
    Front wheels with zero toe in/out is best. If it were simply a front wheel drive car then a small (1mm) toe out is recommended but as it is AWD they seem to function better with zero.
    Don't forget to drive it slowly in a tight circle on concrete or asphalt surface and see if you can sense any "hopping" in the steering. If it does this the viscous coupling maybe on the way out... there are a couple of other tests for this as well... search Range Rovers in the P38 (4.0/4.6) section " common problems and fixes" . If so, it needs to be addressed early... (pls don't ask how I know this)
    May 2008
    Welcome Mick, we all wish you a happy ownership with your P38 and that you find this forum useful.
    In my experience with 16 and 18 rim wheels, the 18's tend to be more inclined to track and their lower profile gives a harsher ride. Still, they look good on the road.
    Cheers, Paul.
    South Australia
    Thanks for the replies guys.
    Will deffo check the tyre pressures, and I'm out with SWMBO this arvo - so plenty of driving round in circles (LOL).
    I set the toe to about 1 degree toe out yesterday morning before went on our excursion, and am happy to report that the steering issue was pretty much fixed. There is still a very small amount of 'tracking' (bump-steer?) - and I will have to agree with Paul, that as soon as i changed from the 16's to the 18's (on Friday) this was much more pronounced (maybe more noticeable as a result of the steering issue), so this could simply be the larger rims. The effect lessens when the EAS is in highway mode. (was actually pretty impressed with the handling down the country lanes out to Victor Harbour)
    There is still a bit of a residual 'looseness' to the steering, which I think may something along the lines of a tie rod end. It's just a really, really small, occasional 'knock' felt through the steering wheel. I really need to get both wheels up in the air and have a bit of a closer look to see if I can determine where this is coming from. I may also zero out the toe, as parallel makes more sense.
    The wheels were balanced by Triumph Rover Spares when I bought them, so (at this stage) I will assume that these are okay.
    Only other thing I noticed, was that at 100kph, we developed what I can only describe as a high pitch 'whistle', it almost sounded like wind noise, but I don't think it was. Anyone experienced something similar before?
    Mick.
    re. the high pitched whistle above 100kmh
    1. check SWMBO is not inhaling/exhaling through clenched teeth
    2. ...does your vehicle have the OE "sportz bars" fitted?
    If so, there's an insert strip of rubber-like material which is designed to fill the channel on top of the bars. If this is missing the air flow causes it to whistle...like blowing across the top of an empty bottle replacements available from roof rack suppliers
    3. Check also for correct alignment of the sunroof when closed
    South Australia
    Nope, there's no racks fitted, although I'm looking to buy some so that I can fit a full length rack for the roof tent, so will make sure I check to see if those strips are included. (cheers). Although... the noise sounds very similar to how you describe it - blowing across the top of a bottle.
    I would say that the sound seems to be emanating from the lower front offside area - perhaps related to the steering / alignment / whatever issue??? - although that could simply be my paranoia.
    Mick.
    South Australia
    Here's some pics of the beast, for those who're interested.
    Douglas Park, NSW
    Quote Originally Posted by T34 View Post
    Check the top windscreen mould. It can lift along the leading edge resulting a bit of wind noise.
    Jan 2010
    Newcastle NSW
    18 inch or 16 inch wheels?
    Hi all, my autobiography has 18 inch wheels and i dont think it rides or tracks as well as my old hse with 16's. Any ideas? And if it isn't just me, where's a good place to get 16's from?
