Results 1 to 10 of 11
Thread: swb weight
    Oct 2006
    canberra
    swb weight
    giday all im purchasing 2 series 2 landys one is diesel one is petrol ones a full hard top the other a truck cab im just curious as to how heavy one of these are i have to tow them a long way tottenham to canberra and dont wish to be stuck with a broken trailer or what not from over loading
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Quote Originally Posted by 460cixy View Post
    An SWB is about 1300kg, an LWB is about 1500 kg, depending on what you have installed.
    Peter
    Sep 2010
    underneath the stars
    i think it is around 1300 also, does depend on oils and fuel because all of this can add a fair bit of extra weight well maybe 60kg but still.i am assuming you are taking one at a time, if so you will have no problems.
    papa smurf
    d@rk51d3 Guest
    Tare weight 1315 kg.
    drifter Guest
    If this works, you should see a chart for both the 88" and the 109"
    Sep 2010
    thanks drifter i have saved that page
    papa smurf
    drifter Guest
    PM me an email address and I'll send you a bigger copy of it.
    Bribie Island QLD
    On the rego papers of my 88" station wagon it says Tare 1010 GVM 2020.
    drifter Guest
    How peculiar
    I got my info from here:
    Quote Originally Posted by crispy View Post
    That is not correct. In addition the 88 is not a 1 tonner, indeed the standard long wheel base is not a one tonner. You need a one ton 109 landrover to carry the weight indicated on your papers.
