Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: X eng deflex kit
    Yinnar South, Vic
    X eng deflex kit
    Righto, Drew at Hiline4wd has been in contact with Rovacraft about these for me and looks to have a price of $600ish landed in aus via sea freight,
    X-eng High Performance Off-Road Engineering
    The price may vary a little according to the dollar at the time
    But far cheaper than the $800+ landed direct from x eng
    Yinnar South, Vic
    Quote Originally Posted by JohnR View Post
    Put my name on the list I've been trying to design something like this for a while now. I think $600 is well cheaper. The only question I have is, has anyone investigated if it can be engineer approved?
    Can't answer that one sorry John, Andrew was thinking the same about making something till I quizzed him about getting them in
    Gold Coast, QLD
    looks like a good bit of gear.
    Just want to clarify if you do not have the factory sway bars then you need to change axles housing and make mounts on the chassis. correct?
    I rule!!!
    2.4" of Pure FURY!!!
    99.87 MB
    So thats an axle half shaft and a locking hub????
    Well I'll be stuffed! Awesome.
    Slunnie
    Yinnar South, Vic
    Quote Originally Posted by Grimace View Post
    Yea, I'd say yes, I've never paid enough attention to see which rover chassis had the flat plates to mount the sway bar, but if you don't have the diff mounts, you can buy them from 'ere
    055 o s Rear anti roll bar bracket
    Which I'll also be making a large buy from, so Myself and Vern can attempt to build a couple of front salisbury's
    Jan 2009
    Bullsbrook W.A.
    can it be fitted to a 130 with a long range tank?
    if so i would be interested in ordering one.
    Ian
    Yinnar South, Vic
    Quote Originally Posted by bully130 View Post
    Ian
    I'd suggest you'd have to lower it to clear the tank with longer bolts and spacers, whether that's a good idea would depend on the driving you do, good for a tourer, not so much for a play thing I'd be thinking
    Oct 2006
    kinross, Perth, WA
    for your interest my 110 extreme 2002 doesnt have sway bars but does have the mounts front and rear on the chassis..
    and just checked the rear axle (rover type) and it has the bracketry on there already..
    Steve
    VIC
    For the stupid questions. Is it for use on front, rear or both?
    That price is for one end, I assume with confidence?
    NSW far north coast
    LOL, I sat down and designed one years ago with a sliding/locking spline on one end but the X-Eng one is much simpler and therefore better
    Actually his is much, much better, it's real, mine never got off the drawing board.
    I reckon it's too stiff for the rear only though, it'd make things really taily for most Landies, you'd need one up front for balance but it's probably about right for a heavily loaded 130.
    BTW, look under the back end of a GQ Ti spec Patrol wagon and they used a disconnecting drop link on the rear ARB with a cable and lever under the dash so you could lock/unlock on the move.
    Worked well
