Juddy,
The metric 255 Michelins are not all that much wider than normal 9.00x16 tyres (they are about an 1" higher though). The Michelins are used on 101s quite often and wheelarch extensions are not required.
I would wait until your vehicle arrives and then work things out - nothing may be required but if it is the cheapest and easiest option are the cheap rubber extensions that you buy by the meter - at least until you work out what you want to do. The 101 has rubber extensions on the front arches as standard to cover the standard 9.00x16s and if wider rubber is used the rubber extensions are easily screwed onto the rear arches.
