IIRC towing in 5th with a R380 isn't recommended
Hey all,
just after some advice after taking out 5th gear in my defender (R380) as a result from towing a caravan.
Is towing a camper trailer in 5th gear going to cause the same issues as towing a caravan.
depends on how much right boot and how heavy the camper is.
Correct.
The R380 is quite good in its application , especially the later suffix K and L boxes, as they have bigger LAyshaft bearings and stronger mainshafts aswell. Check Ashcroft engineering in the UK for a rundown on these transmissions.
5th gear bearing support is better in these boxes than most others, and I wouldn't have any worries with a camper trailer up to 1.5t, and an unchipped Td5 or an untweaked/ tweaked Tdi.
JC
You'll be fine then, just adhere to 20,000km trans oil changes if doing heaps of towing, or 40K intervals with normal use. Use a good quality oil, Castrol Syntrans is the best, We use Valvoline Duragear 75w85 and it is fine and not as $$$ as Syntrans. However, at 40K intervals $25/ litre isn't much when 2.7litres is involved.
JC
I did 45000 ks around Aus towing a full to the brim camper trailer and most of the time that was in 5th in a r 380 with no problems at all
Sent from my iPhone using Tapatalk
95 300 Tdi Defender 90
99 300 Tdi Defender 110
92 Discovery 200tdi
50 Series 1 80
50 Series 1 80
www.reads4x4.com
