Results 1 to 9 of 9
Thread: L322 lights on P38
    Nov 2005
    Maudsland, QLD
    L322 lights on P38
    Has anyone put L322 headlights on a P38??? If so what was involved?
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    why would you bother?
    If you look on rangerovers.net you'll threads about it.
    The headlights do not follow the bonnet lip profile and thus look odd.
    Nov 2005
    Maudsland, QLD
    Quote Originally Posted by Hoges View Post
    Was thinking it might be an easy way to do a HID light upgrade
    Dec 2008
    Paris, France
    Quote Originally Posted by Steinzy View Post
    Put some H4 bixenons in your headlights and you'll see the sun at night
    Apr 2010
    ArmidaleNSW
    Dec 2008
    Paris, France
    Quote Originally Posted by Fish78 View Post
    That's not a kit but a conversion done at the body shop.
    South Australia
    I read up on this before I bought mine. I considered doing this but then decided to leave alone. From what I understand the light housings need to be trimmed to fit in the same space as the P38 units. There is also some modification needed to get them electrically connected - I seem to recall seeing an L322 to P38 wiring adaptor on ebay for this purpose.
    From what I recall, there is also an issue with the automatic levelling. Either the L322 units don't have it, or they do and it will not work (cannot remember which).
    Most of the conversions that I've seen pics of also change out the grille too. This is also a fair amount of work as I believe they are physically longer and require trimming and refinishing. Best grille I saw was one where the owner had drilled holes in the stock P38 grille to make it resemble a sport. It looked pretty good, but lots of work, and I can only imagine that if I tried it I would mess it up on the second from last hole - lol
    Whilst I like the front light conversion - the rear light conversion looks like dog doo. And the only light that seem to be available are the kits mentioned previously.
    Best front conversion is the one where the front bumper is also changed, but add the cost of this conversion + L322 wheels + Rear conversion to the cost of a P38 and you're practically in L322 territory.
