Hi....new member, and I have an issue I need help on....I have a 2006 Disco 3 TDV6 to which I have just fitted Cooper ST's, as I do genuinely go 4wd ing and intend to do a lot more. As expected, I get a definite road hum from the chunky tyres, which I can live with, but what is really really annoying is a "harmonic vibration" rattle that comes directly through the steering column, but only at speeds of between 56kmh and 60kmh....the most common speeds around town! My local service guys could not be bothered and said to remove the tyres (der) so I have tried to solve myself with no luck. I have taken off the shroud and all plastic covers, etc but just cant seem to isolate and eliminate the noise. I have had the tyres re balanced and aligned twice, plus I have jammed things in nooks to try and stop the vibration, but it seems that it isnt going to be fixed by anything I can do, rather its a more involved technical solution that is needed. It is really bothering me (and passengers) and I would greatly appreciate some advice. (Or if anyone can point me in the direction of someone who understands 4WD's in Adelaide and wont just suggest taking the tyres off, as if I am an idiot!) Cheers!
 Annoying rattle!
 Annoying rattle!
 D4  2.7litre
D4  2.7litre Originally Posted by ADMIRAL
