Results 1 to 9 of 9
Thread: cant unlock the back door
    Jan 2010
    labrador
    i went to unlock the rear drivers door today and it wont unlock
    any tips?
    also the two front doors have gone all stiff
    agian any thoughts / tips?
    both happened on return from 2 weeks on fraser
    thanks
    Near Seven Hills, Sydney
    My rear door lock wouldn't lock for a while till I adjusted the door striker. But yours sounds like a Fraser induced corrosion problem. Shoot the locks with some wd40 or similar, or at least a decent blast of fresh water.
    Mar 2010
    Mudgee-ish
    My drivers door went stiff for a few days (last July) then got stuck in lock mode. Took the trim off and found a little plastic lug had broken. Looked like it was meant to hold the linkages in place and they had kinked at a sort of elbow. Just popped it backed (sort of like a dislocated shoulder) and it worked perfectly. I just don't get too vigorous with the key when opening.
    miky Guest
    Quote Originally Posted by scottygc View Post
    any tips?
    thanks
    What vehicle? Or are we supposed to guess?
    I had the same trouble on my day old Puma wagon.
    My son then explained about child locking systems
    Well... how was I to know? Never had a car with child locks before. Then again, never had a car with central locking either.
    Aussie Expat in NZ
    Quote Originally Posted by isuzutoo-eh View Post
    Might be a getter idea to use graphite powder or something to lube the locks as wd40 or similar will end up attracting dust and crap and /really/ getting stuck.
    Quote Originally Posted by flagg View Post
    Good point. I was thinking it'd already have salt/gunk/corrosion in it, so something pressurized would be good to clear it out. Maybe an electronics cleaning spray followed by graphite when its dry. But graphite alone won't budge any already accumulated gunk.
    Jan 2010
    labrador
    ok sorry
    its 2000 110 wagon
    its not the rear wagon door it is the passenger door drivers side
    the lock latch on the door trim will not slide up to unlock so i dont think it is the child lock(dont think it has child locks)
    when i try to unlock it i can feel it jamming on something near the door handle on the outside
    ill have a better look at it this week end
    thanks
    Aussie Expat in NZ
    ok sorry
    its 2000 110 wagon
    thanks
    Ah - yes mine did that. Previous owner ended up drilling through the door trim to unlock it manually. There was a little plastic "thing" that broke
    Jan 2010
    labrador
    well i had a bit of a play with it in the carpark at work on the way home and ive unlocked it
    i jigged with the lock and the door handle
    ive given the thing a good squirt of silicon spray and i will have a good look on the weekend if it stops raining long enough
    ps: yes it dose have a child lock , but it wasnt on
    thanks all
    now to work on the stiff doors
