Thread: Series 1 Bonnet
    Nundle
    Series 1 Bonnet
    I know a Series 11 bonnet looks similar, but can anyone tell me whether they are the same as a Series 1 88/109.
    Numpty
    REMLR No 143
    Queensland
    S 1 950mm long 800mm wide at front
    S 11 985 long 830 mm wide at front
    The S11 has a flatter curve at front than the 109 S1.
    australia
    Quote Originally Posted by 123rover50 View Post
    hi the i09 hinges are 30 mill longer the bonnetts are different pm
    Nundle
    Tis what I thought.
    Numpty
    REMLR No 143
    No, and what is more, all Series 1 bonnets are not the same -88/109 are different from 86/107, and I have an idea that 80" are different again.
    There are at least three different styles of Series 2/2a/3 bonnet (plain, deluxe and deluxe with wheel well) but all are interchangeable - Series 2/2a hinges and Series 3 hinges have the same holes although 2/early 2a have an additional hole. There are at least three styles of buffers for the spare, with one or two holes each.
    Nundle
    I did realise this John, hence why I asked specifically for 88". And yes, 80" are different as well.
    Numpty
    REMLR No 143
    Quote Originally Posted by numpty View Post
    I thought you probably did, because of the way you asked, but others reading it may not have, so it seemed like a good idea to spell it out.
    Further on the subject of bonnets, I would not be surprised if there was more than one 80" bonnet, and further to Series 3 bonnets, the Stage 1 bonnet is not interchangeable with other Series 2/2a/3 vehicles, but is interchangeable with 90/110 and Defender, up to the Ford engined ones, I think, although there may be clearance problems with the TD5.
