Results 1 to 10 of 14
Thread: uhf cb @ antenna
    May 2010
    brighton, brisbane
    uhf cb @ antenna
    G,day, just purchased G.M.E. TX3220 RADIO and ZCG Scalar antenna, model ZN3-77-10, [ground independant.] I'M very much like Sgt. Shultz on this, intend installing radio on the dash[centre], antenna on bullbar, good choice, or is there a better alternative? look forward in eager anticipation to any replies, Cheers, Bob10
    Melbourne, outer South East
    Sounds OK - but about putting it in centre of dash do you mean on the top ? - You don't say what type of car you drive.
    Jul 2007
    Yes the antenna if ground independent will be suitable for bullbar mounting, or anywhere else for that matter. Height is might when it comes to UHF so if you have somewhere else that you can get it up higher you will be marginally better off. Not worth the effort of getting another clamp if the bullbar has a bracket built in.
    May 2010
    brighton, brisbane
    radio& antenna
    I drive a Disco2, and I'm thinking about making a bracket for the top of the dash , above the am/fm radio. Would there be an advantage in putting the aerial as close to the edge of the bullbar as possible, to give better reception from behind? Look forward to your advice, cheers, Bob10
    miky Guest
    Quote Originally Posted by bob10 View Post
    As has been said many times before, it is usually a compromise wherever you put the antenna.
    The "best" place is in the centre of your roof - on the roof rack or bar or drill a hole in the middle of the roof
    Most people who have a roof rack or bar would put it on drivers side of the rack to keep it from hitting branches all the time.
    Again, in practice the bull bar will work OK most of the time.
    Aug 2010
    Quote Originally Posted by miky View Post
    On my road car I have a roof rack mounted shorty antenna on the drivers side and this was chosen specifically to stop it hitting branches, etc.
    Bullbar should be fine for most antennas as long as they are not too short as height is might.
    If all you are doing though is talking to other folks nearby, for example, travelling in convoy and never get more than 1000 metres apart then almost any antenna will do. I know that my half-phase short antenna on the roof regularly picks up and transmits to the local repeater 20-30 kilometres away.
    North Avoca
    MobileOne
    There's a lot of useful information on antenna mounting on this site.
    www.mobileone.com.au
    They're also an Australian manufacturer and very good to deal with.
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    Sydney, NSW (nr Epping)
    SNIP
    SNIP
    Hi Miky,
    I take issue with this comment. With ground-dependent antennae this was the case. Fortunately now, with ground-INdependent antennae, height is might, but placement is not.
    HTH,
    Peter
    Jul 2007
    Quote Originally Posted by Bushwanderer View Post
    Hi Miky,
    HTH,
    Peter
    You still get benefit from a reflector, which the roof is. A reflector can give you another 3db of gain.
    With monopoles you need a ground just to get the antenna to radiate as designed. The ground independent antennas are usually a dipole i.e., centre fed wip.
    Hi slug_burner,
    While I don't question your statement, do you have a source for me to educate myself?
    TIA,
    Peter
