Results 1 to 10 of 21
Thread: how much weight does a defender roof take
    Feb 2005
    well i just removed my old one....now i always thought it was heavy duty but
    at this stage i have only weighed the rack, keep in mind when i brought the truck i removed some weight, maybe 10kg
    105kg for the rack alone, it was a four man lift to get it off, my new roof rack is maybe 30kg which means i have a 75kg gain
    umm, i have loaded the following for extended touring on the old rack
    12kg solar panel - on all the time
    5kg awning - on all the time
    35kg second spare
    60kg+ 3 x jerry cans
    ?? 3 x swags
    6kg 2 x gas cylinders
    no wonder the pillars used to sound like they were straining under the load approx. 220kg at least i will be down around 150kg for my next trip
    From memory its only about 75kg including the roofrack
    kenleyfred Guest
    Puma limit is 150 kg. Checked into that before purchasing everything I now have on the roof.
    Perth, WA
    Quote Originally Posted by kenleyfred View Post
    Where did that figure come from kenleyfred??? All the figures in the brochures and owners manual for the 2007+ defender 110 and 130 say 75kg including the rack.
    Kingston, Tassie, OZ.
    It's a wonder you/ the vehicle hadn't fallen over!
    JC
    Feb 2009
    Quote Originally Posted by TimNZ View Post
    The Owners Handbook I got got with my 2010 Defender says 150 kg. The Handbook is dated 2007.
    You can find the Handbook here: TOPIx - TOPIx The relevant section is "Load Carrying".
    KarlB
    Perth, WA
    Just had a look Karl, you're right, 150kg. I wonder if the limit changes depending on location??
    Scarborough, QLD
    35kg second spare
    ?? 3 x swags
    so, show us the new one!
    Feb 2009
    I thought the same as you Tim and raised the issue on the Pommie based Defender2 Forum but was infomed I was wrong.
    KarlB
    Mandurah, WA
    2005 defender td5 - 150kg......
    geck
