Results 1 to 10 of 39
Thread: Light Bar for my RRC
    Aug 2010
    Sunbury, VIC
    Well, I started a project today that I thought would be closer to the bottom of my list, but the planets alighned and I came across all the parts I needed to get going on this. The Lights are only cheapies - $99 for all 4! Can't go wrong for that price, and if I end up cleaning one of them up on a tree sometime, I won't be heart broken. I also mounted 5 white LED clearance lamps on the front as well ($7 each). The roofracks were lying around, as were the old rectangular Hellas I have mounted to each side, and the aluminium checker plate came from my local metal fabricator who I use a lot for work, so that was a freebie. Added to that was 4 relays, and other electrical stuff.
    Bolted the checker plate to the roof racks, and the whole thing came out really ridgid so there is no flex at all in it.
    Photo 1 - Just showing all the bits and pieces.
    Photo 2 - All together - still to be wired
    Photos 3 & 4 - Test fit to Rangie.
    So now all I have to do is wire it all up... and put a bigger alternator in.... I don't think the standard 55 amp job will get me far - the total load for this lot will be close to 50 amps on its own, with out the headlights or anything else on - I will also be adding a couple of bigger lights to the Bull bar once I get it. Will start the wiring tomorrow, and I'll post a few more pics once it is all done - somewhere where it will show the vehicle off a bit better.
    Cheers - Gav
    Rangier Rover Guest
    Looks interesting.... Hope you like being pulled over a lot
    Apr 2007
    Prospect SA
    Lots of lights but the question begs WHy?
    They are no good in the bush due to branches, car parks in the city and being totally illegal is another.
    Buy a good set of Light Force 240's or better still same in HID and you be laughing and legal.
    How good would that be.
    My tiler has Hilux with 20inch rims and ultra low profile tyres with lights and crap every where.
    It looks ridiculas but hey--Beauty is in the eye of the Beer-holder.
    Quote Originally Posted by big guy View Post
    Hey Mr Guy this fellow has clearly put a lot of work into this project inc posting pics etc so non productive, illinformed, lazy or quick posted comments are hardly helpfull.
    His setup is legal if properly switched. Maybe he spends more time on open highway and beachs etc and not on the bush tracks or carparks. Finally he has a 20 year old RV8 (that is hard to keep cool at the best of times) and if he following your tip of putting a bunch of LF 240's on his front bar maybe he would look forward to a cooked donk.
    ...a bit of thought and tolerance before posting please
    Aug 2010
    Sunbury, VIC
    Thanks Cockie55 - you are right on a number of counts there - I do a lot of highway & freeway driving at night, never go into the city (Why would you???) and don't do a heap of off road work - mostly just into the bush camping. I believe you can have 6 main beams, switched by the hi/low switch, and able to be isolated, so meets all these requirements, so I believe they are legal.
    Indeed beauty is in the eye of the beholder, and I quite like them - I have seen plenty of stuff on this forum that I don't personally like the look of, but I hold my tongue, or try to be constructive. Not sure why Rangier Rover things I will get pulled over a lot - I have had a similar set up before on a ute & my old Suburu wagon - never been hastled before for this sort of thing - maybe in the city this is frowned upon?? and it is heaps more common now than it used to be 20 years ago...
    Having said all that - I am happy to listen to anyones opinions or comments - I have a thick skin, and it takes a lot more than a few comments to get to me - The world would be a boring place if we all liked the same thing. Also a set of Light force 240's with HID's would come to a lot more that the $150 bucks this lot cost me - and as Cockie55 mentoned, with those mounted up front, that wouldn't help in keeping the old girl cool...
    Keep the comments coming - if what I have done here isn't your cup of tea, you will probably hate some of the other ideas I have in mind for her... I'll keep postin' 'em - you keep knocking 'em..
    Cheers - Gav.
    Well Gav....
    I like it
    And as long as you wire it right it's legal
    I loved my roof lights, used correctly they are a great safety feature. And bloody handy.
    Aug 2010
    Sunbury, VIC
    Cheers Tombie - anyone who has used a roof mounted light bar would appreciate how good they are. They will be wired legally so I don't see an issue.
    Once they are up and running I'll take some night shots and post them.
    Cheers - Gav
    Apr 2007
    Prospect SA
    Quote Originally Posted by cockie55 View Post
    Well, lazy and ill informed is probably not a good way of descibing me but as you don't know me I let it slide.
    In Sa, the ADR states that more than 4 forward facing headlights are in fact illegal. None to be mounted any higher than the centre line of your head lights.
    O.K its possibly legal in your state, I have not checked.
    A bunch of 240"s, No, 2 is plenty and they will give out more light than you anyone could possiblt wish for. So much so I now have the 170's as they are plenty and yes they do give more airflow to the radiator.
    A light bar on the roof---Come on though be real!!!
    Perhaps I should keep some thoughts to myself but some times I just can't help myslef.
    Crafers West South Australia
    FYI this is what I found on this site:
    http://www.tmr.qld.gov.au/~/media/5f...orvehicles.pdf
    Specific (Driving lamps)
    • Two additional pairs of driving lamps may be fitted to a motor
    vehicle.
    • The driving lamps must be mounted symmetrically on the vehicle.
    • The light emitted must not cause the driver discomfort either
    directly or indirectly through the rear view mirror and/or other
    reflecting surfaces of the motor vehicle.
    • Driving lamps must not be placed wider than the dipped beam
    headlamps.
    • The colour of light emitted from driving lamps must be white.
    • Additional driving lamps must only operate in conjunction with the
    high beam circuit and must be fitted with an independent on/off
    switch.
    • There is no individual height specification for the fitting of driving
    lamps.
    General comment
    Section 219 of the Transport Operations (Road Use Management – Road
    Rules) Regulation 1999 requires lights not to be used to dazzle other
    road users and states:
    "A driver must not use, or allow to be used, any light fitted to or in the
    driver’s vehicle to dazzle, or in a way that is likely to dazzle, another road
    user".
    Additionally, Section 57 (Schedule 1, Part 7, Division 1) of the Transport
    Operations (Road Use Management – Vehicle Standards and Safety)
    Regulation 1999 requires:
    "A light, other than a high-beam headlight, fitted to a vehicle must be built
    and adjusted to provide the necessary amount of light, without dazzling
    the driver of another vehicle approaching, or being approached by, the
    vehicle".
    So it appears to be legal in Queensland at least. Probably elsewhere too. Importantly the rules for auxiliary headlamps are not the same as for the original lamps specified by the ADR's.
    Aug 2010
    Sunbury, VIC
    So legal in Queensland, and I believe most or all the same rules apply in Vic, but I have yet to find or be shown the equiviland standard. I am basing the legallity on a bit of heresay, and that no one I know that has these now or in the past (Including myself) has been hastled by the Police about them - I suppose only time will tell. If someone does know where to find the relevent Vic standard, I'm happy to be corrected on this if it is not the case. I also doubt it is the most illegal mod I have ever had on a vehicle ...
    I'm suprised I have created a thread that has caused so much discussion - from both sides, but I'm glad to be of service.
    Cheers - Gav.
