Results 1 to 10 of 23
Thread: Gas Injection just fitted to my 95 V8 Disco and its not running at all
    Ferntree Gully, Vic
    Angry Gas Injection just fitted to my 95 V8 Disco and its not running at all
    I recently had an Impco Sequential Gas injection system fitted by Deacon Automotive.I supplied them the system and all they did was fit it and tune.Parts supplied by me were :
    - Gas injection and all its components (bought second hand)
    - Scuba style tanks off my old Disco. (only 3yrs old)
    They had fitted alot of these systems to Discos and Rangies and had no problems.Well since i have got it back from them i have had nothing but trouble.The car doesnt idle and it sounds like it runs on 5 cylinders when you drive it.And it has hardly any power.So basically it is undriveable.
    The gas in the tanks was about 2yrs old but i filled it more then half with new gas.The ignition is up to scratch with new leads suited for gas,a new coil,a scorcher dizzy and new plugs as well.So basically after stuffing around with it for a few days they told me it is basically just "bad luck" that its not running on my Disco.Those were his exact words.And have left me with a gas system that doesnt work!
    It runs great on petrol and while it was there they fitted a new standard cam and lifters.So where do i go from here? What could it be that makes it run like this? After forking out all that money,which took me ages to save and now i have a gas system which doesnt work.Any help would be great.
    Chris
    I wish I could offer some useful info. I can understand how you feel.
    Too bad you're not near Crafers West in SA.
    There is some bloke there who knows Landies and LPG. Bee Utey is, I think, his username.
    Crafers West South Australia
    I have fitted a couple of these systems, easy enough to fit, but I was not all that impressed with them. One of them ended up with a failed injector, took absolutely ages to get another sent for warranty. Customer was not amused, was going to call consumer affairs.
    Now in your case I would first do basic diagnosis, that is to check all the gas injectors for electrical function. Use a multimeter and compare their resistance readings. Then check which injectors are not running, squeeze the injector hoses shut and see which ones function. Then swap injector plugs around to see if the fault follows the plug or the injector. The D1 won't care which plug fires which injector, it's not sequential.
    It may also be that there is contamination sticking your injectors closed. Try running some carby cleaner into them. you will have to de-mount them from their rail though.
    Nextly there is a tool available from the UK to see what is happening in the gas ECU:
    BRC LPG sequential injection ECU interface & software - eBay, Other Car Accessories, Car Accessories, Vehicle Parts Accessories. (end time 20-Oct-10 09:39:06 AEDST)
    I am thinking about getting one for servicing but have resisted it knowing I might not install another one of these systems.
    Kingston, Tassie, OZ.
    Also, 'Pibby' a member on here, has just done a mountain of problem solving and research on his poorly performing seq system, and solved most of the problems himself. He has one of these diagnostic programs IIRC. I was very impressed with his tenacity.
    Might be worth PM'ing him a few Q's?
    JC
    pibby is offline Master Silver Subscriber
    Sep 2009
    tasmania
    Sprover – I’ve got a kme system which is distributed by elko. By virtue of the local gas fitters lack of knowledge of land rover I ended up purchasing the software and cable to perform my own troubleshooting. So I guess in your case work out what you are happier to do – buy the cable/software and troubleshoot yourself or take the vehicle back to another installer with knowledge of land rovers. Personally I’d get the software and save yourself having to visit a gas shop each time you have a problem. It is a steep learning curve at first but you soon work your way through it. nonetheless, there are some things you can do without it which will hopefully find your problem.
    Bee utey does this stuff for a living so I’d recommend what he has said. I do not know about the impact of old gas ……From what I have learnt messing around with mine and going on what you have said, if it sounds like it is not firing on all cylinders then start with that. as bee utey said these are a batch fire system not sequential so you are just checking that the gas injectors are firing and not worry about the timing of the gas firing in relation to the petrol injector. As a high level check if your car has 2 or 4 injector banks have your car idling on gas then disconnect/reconnect (there will be an electrical connector plug going to each injector bank) one injector bank at a time and see what impact each bank has. If you disconnect a bank and there is no difference to the running of your engine then that is all or part of your problem.You might be lucky and find that one bank is causing your problems. Next, either test electronically as bee utey said or on my vehicle I would disconnect the hoses off the injectors on the side going to the intake manifold and turn the car over on lpg not petrol on the starter and check that each injector is firing gas and that they all sound/behave the same way. armed with this info then it will be easier to determine what to do/look at next. (you can force the system to start on lpg on my system by holding the button which turns the gas power on/off down for 10 seconds. Your system will have something similar).
    If an injector is not firing then it can be either mechanical or electrical. As bee utey said it might have some gunk caught inside it. I pulled mine completely apart and ran new rubbers/seals through them but cross that bridge if the diagnosis shows it to be the case.
    Try that for starters and good luck. Post the results of your troubleshooting and hopefully the forum members can get to the bottom of it. It can be very frustrating getting this stuff sorted but once you do you’ll love driving on lpg. But you’ll need to get your dissy regraphed for lpg – though one step at a time.
    Warrandyte, vic
    I have nothing useful to say to help you with fault finding but had deacons do gas injection on my D1 for a teriffic result. Had the mixer changed under warranty after 3 weeks when it failed but apart from that no problems. They of course specialise in LR's and gas conversions and have done, I'm sure, thousands of them.
    That being the case I tend to lean towards it being a hardware problem rather than an installation problem.
    Do you know why the gas injection system was taken off the donor car? Was it woking properly?
    BTW the response they gave you is very unsatisfactory and perhaps some discussion about consumer affairs may help illicit a better response.
    Ferntree Gully, Vic
    Quote Originally Posted by trobbo View Post
    I went to Deacons because they were a Landrover specialist and had done alot of these conversions before.And i did hear alot of good things about them.But after the way they dealt with me i will not be going back there again! As for consumer affairs,they are very high on the list of THINGS TO DO.
    Regarding all the other replies.Thanks heaps.I will be trying all the suggestions sometime this week when i get a chance.Or when i can be bothered After all this it really just makes me angry to even work on it considering the money i paid them.
    I will be trying your recommendations PIBBY and BEE UTEY and will post up any improvements or new dints in the side of the Disco. Hopefully its only something small and i will be happy as Larry .
    Chris
    Oct 2007
    officer, Victoria
    if all else fails take it to range rov they did a great job of fixing up the gas system om my disco
    Ferntree Gully, Vic
    Update
    Tried a few things on the Disco the other day to try and chase this
    problem with the gas.A few other things i have noticed are that when
    you rev it quickly off idle there is a miss down low.But when you hold
    the revs higher up around 2000 RPM and rev it, seems to be fine.The idle
    is still erratic and hunts alot.Although it seems to be hunting alot on
    petrol now as well.
    All of the injectors seem to be working.You can feel the pulsing going
    through all the lines.Each injector plug was also removed and swapped
    with another one and the revs would drop then rise back when it was
    disconnected and then re connected.All while holding the revs a liitle.
    I tried to take the injector out but it has some kind of special clamp holding
    the line so i couldnt get it off.And i was starting to get a bit frustrated
    at this time.
    Im thinking maybe the injectors are blocked.If it was the injectors how much
    would i be looking at to replace them? Although i will try to flush them
    first.Im at the point now where i dont want to work on it after all the
    money i paid and im losing interest in the Disco.I dont want to get rid of
    my Disco but this is starting to push me to my limits.
    Chris
    Sounds like you need to find the software to tune it. Or someone who has it and knows how to do it. Nextly all the usual things like spark plugs, weak ignition amp, plug leads and timing still apply. Plug gap no more than 0.8mm, best 0.7mm, 1 heat range colder than standard (e.g Bosch WR7DC+) , timing 10 degrees BTDC. There is usually a pressure adjustment on the converter, a hex socket screw against the pressure diaphragm. An increase in pressure may be enough to get some go.
    I doubt that the injectors are partly blocked, black goo usually just sticks them shut.
