Results 1 to 9 of 9
Thread: Defender Door Hinges
    May 2002
    Heathcote (in "The Shire")
    A quick question
    Defender front door hinges (top one) if I remove the door bolts are the nuts captive with the door or do I have to strip the door linings ?
    Looking at trying to tighten the mirror bolts a bit.
    Martyn
    Feb 2005
    i had a look at a stripped 130 300tdi the other week, yes they are captive providing the elements haven't got to them......
    Oct 2007
    Wantabadgery, N.S.W.
    I've had mine undone and they are NOT captive on the door side. can't comment on the body side. (my97).Don.
    Feb 2005
    i was looking at the door frame....cannot comment on the door
    South East Tasmania
    I have the same problem, they are not captive so you have to remove the trim.
    I do not like to remove the trim here in Bundy because for sure the holding clips will break.
    I am holding the mirror tight with a bit of shim, cheating but effective
    JDNSW's Avatar
    Just confirming - captive in the door post, not in the door.
    dmdigital's Avatar
    What he said
    On the Puma with the Plastic door trim you can sneak a spanner or a bit of blu-tac in to hold the nut in place. On a Tdi you find the nut in the bottom of the door somewhere
    May 2002
    Thanks everyone - will have to allow a bit more time.
    Martyn
    I was able to just get in beside the trim without having to remove it. But as others have said, don't drop the nuts inside or it will need to come off.
    '51 Series 1 80"
    '12 Defender 90
