Results 1 to 10 of 29
Thread: What initial and preventative steps for new owner?
    Oct 2010
    Carindale, Brisbane, Qld
    Hi Guys
    As per the intro's forum, I am a new (first time) RR owner and I am trying to get some tips about must-do first jobs on a new Rangey (2000 HSE w LPG/Petrol).
    I have read lots, but if you were to get a new Rangey with an uncertain history, what things would you do straight away? The EAS seems fine, but during the RWC, engine is coming out (today) to get oil leak fixed on some front seals near crank.
    Check main computer connectors?
    Spray penetrating oil on plugs?
    Check seals on Eng Mgt module for water entry?
    What else?
    Many thanks for any input.
    Mar 2009
    Melton West, Victoria
    First off - welcome
    If your engine is coming out you might as well give the electrics a good going over. Check the fusebox/relay panel under the bonnet and give it a good inspection - checking for any signs of fried/frying relays. It's probably worth taking pretty much every electrical plug in the engine bay apart and checking for any corrosion - fixing as necessary (sandpaper and contact cleaner).
    Overheating is probably the biggest killer of these engines - so check out all your cooling system components.
    On the LPG side, might be worth changing the filters too if you're unsure of their age.
    Other things I'd do straight away are new pollen filters, new oil filter and oil, new air filter (paper type, ditch any K&N type if it has one installed - MAF's hate them), gearbox oil and filter if unknown, check diff oil, check/replace plugs and possibly leads (good spark is vital for good lpg), check battery condition (weird things happen if your battery is dying - including immobilising your car, ask me how I know ...)
    Oct 2007
    Williamstown, Victoria
    Hi glenhendry, welcome to the forum and congrats on the new Rangie.
    I got myself a 2001 HSE about 12 months ago aside from a couple of minor issues it has been an excellent vehicle.
    The first thing I did was replace all the fluids and filters, that way you know exactly when it was done and what you used, including diff oils.
    Keep good records of the work you do and you'll never be guessing when things were done.
    Don't forget the auto fluid and filter, great guide here:
    Range Rover Transmission Service Description
    As Junosi already said, the pollen filters are good to do, some owners and service places don't even know of thier existence, they can become very blocked and potentially cause other problems with hevac systems. Very easy to do, guide here:
    Range Rover Pollen Filter Replacement
    While you are at it, the plennum filter will probably need doing too:
    Intake plenum filter replacement (Range Rover 4.0/4.6/p38)
    Depends on how far you want to go with it really, but it's good to know everything is as it should be in those departments.
    Another thing you may want to consider is a diagnostic scan tool like the Faultmate.
    I recently purchased a faultmate extreme, I recommend one very highly if you like to do your own work on the vehicle. You can scan for and read any fault codes that may be present, it will also point you in the right direction when trying to diagnose any problems you may have.
    Definately a new set of plugs and possibly leads too.
    That will keep you busy for awhile!
    Good luck with it, regards, Pete.
    Dec 2008
    Victoria
    The cooling system!!!!!!!! Rod [not simply flush] the radiator and also refurbish the cooling viscous fan hub.
    You might also consider replacing the vacuum advance as well. It is probably due for this by now.
    Everythinbg these guys have said...
    with a special emphasis on cooling (don't forget to check viscous fan coupling) and electrical tidy up/refreshes.
    Also, visit hardrange.com.au and check out their P38 upgrades.
    I would say an essential one to get straight away is their EAS Bypass system as its a great get out of jail for if any component of the system fails or breaks. Their prices on Faultmates are extremely competitive too...
    There is a heap of other stuff in their catalogue to consider as well... a lot of it really desirable off roading upgrades...
    Welcome to the forum too. If your not sure on anything, this is the best place to search or ask, bar none.
    Hoo-roo, Dave
    May 2008
    Quote Originally Posted by DT-P38 View Post
    I'll slip you a tenner later
    Douglas Park, NSW
    Quote Originally Posted by Grumbles View Post
    The what???
    Dec 2008
    Victoria
    Oops -missed a word - sorry - - Vacuum Advance Unit.
    Wink
    Quote Originally Posted by PaulP38a View Post
    Cool, you can take it off the bill for my lift kit!!!
    BTW the cheque I was waiting for arrived last week so the ''Pretty Pig'' is now trembling in anticipation of being able to lift her skirts up and jump around with the Hard Rangie!
    One negative though... the Mrs 100 series is not looking happy with losing the 33'' Mudzilla's... I may have to look for a different MT upgrade option to keep them both happy! Perhaps the cruiser would go further with 35's anyway? Oh ****, thats probably gonna hurt the piggy bank!
    Oct 2010
    Can the Vacuum Advance Unit be repaired/overhauled, or is it easier to get it replaced? Although I know what it is and what it does, I see no mention of it in the workshop manual (unless I am searching incorrectly).
