 Originally Posted by
Ashes
				Had the car checked this morning and it appears it is the 2nd battery causing problems.
It was well below charge and was leaking.
I'm getting this replaced with the yellow top optima.
The primary is fine, just needs a charge up.
What I'm not sure of though is why a fault with the 2nd battery would drain the primary.  I have a SC80 traxide fitted and thought
this was designed not to allow the primary to drop below cranking charge.  LR suggested that the secondary in trying to charge itself was drawing from the primary.  I still suspect I had some gremlin which ran the radio
when the car was off and this was what drained the primary.  Possibly the fault with the secondary is a bit of a furphy!
