Results 1 to 10 of 12
Thread: Waterproofing Front Vents/Battery Compartment
    bogboy Guest
    Dear all,
    I have read a few threads about water proofing a defender however what is your best suggestions regarding water proofing and products used with examples if possible pictures.
    - front vents (and still being able to use them)
    - Sealing water from the battery compartment! Aka Birdsville Races 2010 1 my Duel Battery system 0!!!
    Bogboy.
    Def 110.
    Jun 2008
    Quote Originally Posted by bogboy View Post
    I think you could use sikaflex or the like [polyurathane sealant] If you pulled everything out of the compartment and then placed a torch or light under the car you would soon see the main holes to plug. make sure any cable entrys are sealed [gromets sometimes split etc]
    Didge Guest
    There a water leak file under "files" on the front page but I found that when I used a simple silicon sealant on that stupid bit of black foam that separates the windscreen frame from the bulkhead that houses the vents most of my front leaks were solved. In fact I haven't had any since so I think the vents, for the most part, aren't really a huge problem.
    Mar 2010
    QLD
    If you seal the battery compartment so that it's completely watertight doesn't that then mean that it's only means of venting is into the cabin? And if so isn't this a big no-no?
    in the wild New England, NSW
    there is a rectification manual for defender water ingress - maybe something useful/relevant in it
    link on this site - I'll try to find it
    miky Guest
    Quote Originally Posted by jc109 View Post
    Depends on the batteries. AGM would be OK since they reckon you can send them on a plane. Is that correct?
    Mar 2009
    Derbyshire UK
    you could use Series model air vent seals,which are rubber instead of the sponge type used on the Defenders,these give better sealing.
    bogboy Guest
    Thank You All.
    Quote Originally Posted by Didge View Post
    Didge, did you replace the foam or just place the sealant on top of the foam?
    87County that doco was awesome thank you which will help with my other issue.
    JC109 venting into the cabin shouldnt be a issue as everying vents into the cabin thats why we love them so much...
    Bogboy.
    Didge Guest
    bogboy, I just ran a bead of one of those clear Selleys silicon sealants (you know the one that's Wet Seal or something; you can use it on wet surfaces and it skins really quickly).
    Anyway, so far it seems to have worked quite well. Personally I think it would be a good idea to pull out the foam and totally fill it with a really good sealant (but that's just my layman's opinion)
    On the battery front, I spoke to someone in BAttery World the other day and they reckon batteries in the cabin should be dry cells so ventilation shouldn't be a consideration. Any thoughts/ comments on that one?
