Results 1 to 4 of 4
Thread: Recommended snatch strap breaking strain for a Disco 1
    Jul 2009
    I hear snatch straps should be rated to the vehicle. Can anyone recommend what break strain snatch strap i’ll need for my disco 1?
    8000kg
    Moruya Heads/Sth. Coast, NSW
    You shouldn't be buying a snatch strap based on its Breaking Strain you should be basing your purchase on the Safe Working Load (SWL) or Working Load Limit (WLL which is based on a Safety Factor (SF) for your protection. After 1 use the strap deteriorates until it becomes unservicable, if you use your strap at it's Guaranteed Breaking Strain (GBS) it will certainly break. I don't know what the SF is for a Snatch Strap as they are ILLEGAL in the rigging industry, so for safety sake I would use a SF of 4 or 5 to be on the safe side or find another method of Safe retrieval, Regards Frank.
    Ellendale Tasmania.
    Don't take this as fact, but I was told the breaking strain of a snatch strap should be 2 to 3 times the weight of your 4WD.
    Working on that theroy, you should choose 8000kg up.
    OK I found this
    http://www.juststraps.com.au/pdf/Sna...nded%20pdf.pdf
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
