Results 1 to 9 of 9
Thread: County parts purchase ...
    Lithgow, NSW
    G'day all,
    I need to purchase a couple of bits for the County ...
    2 x replacement gearbox mounts
    2 x Head lights
    1 x upper wing light
    I don't have the parts manual as yet ... can anybody tell
    1 - Are County gear box mounts interchangeable with later Defender 110 mounts? If not, what part number should I specify?
    2 - Where is the best place for me to purchase parts in OZ these days?
    Cheers, Simon.
    Simon
    You could try here Karcraft Australia
    they are in Silverwater.
    Or giver Peter at Range Parts a call,he is at Wentworthville.Ph No.98962355.
    Wayne
    lokka Guest
    Ebay has the lot just do a search for county parts most of the
    stuff on there is sold by garry from CLR parts in wimmalee
    i get most my rover stuff from him as his price's are good
    and he has a great range of stuff
    Lithgow, NSW
    Just spoke to Gary from CLR - just up the road from me - he's checking on prices and has the gear box mounts. I went and checked and it appears I seem to have the old original sealed H4 head lights which will need replacing. Says he has an upgrade kit for brighter lights that require the fitting of a relay ... I am a complete numpty with regards anything electrical though - how hard is it to fit new lights with a relay?
    I have to get these bits done for blue slip and rego ...
    Cheers, Simon.
    JDNSW's Avatar
    Relay kit should be pretty easy to fit - should come with step by step instructions. And is a very good idea. You should check with him that it does come with these instructions - if not, there are other kits that do.
    Outer Sydney
    Quote Originally Posted by LowRanger View Post
    Simon
    Wayne
    Quote Originally Posted by lokka View Post
    G'day Simon,
    I'd just like to mention that we have had good experiences with both of these companies when getting parts for our County. Apparently Gary from CLR parts used to be a Landy mechanic so he knows his stuff.
    Edward
    Aussie Expat in NZ
    Have a look here for parts manuals:
    Dave's Interesting Things
    Dave run's this site. (incisor)
    I usually grab the part numbers from the PDFs on the 4BD1 CD and search the net for them.
    Dec
    Lithgow, NSW
    John,
    Thanks for the info on the relay kits ... Gary didn't have the kits, only the lamps for now, but I'll upgrade later and just refit the new ones for now to get me through blue slip/rego.
    Edward,
    Thanks mate ... Gary was a total gentleman and somebody I will be doing continued business with.
    Flagg,
    Ta for the heads up on the Manual CD's ... should I assume that the 4BD1 manual would cover the County also?
    Best, Simon.
    SW of Geelong
    You can get good quality headlight upgrade kits in Dave's Shop through this site.......... Harness upgrade kits
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
