Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: 4BE1 twin oil filter
    Brisbane, Queensland
    I bought one of these from a truck wrecker. Has anyone fitted one of these to a 4BD1?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    SW of Geelong
    Does it look like the one in this pic ? I'm guessing it's likely to be the same housing, but not sure. If it is the same and it's in a County then you'll need spacer blocks.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    lokka Guest
    Quote Originally Posted by rijidij View Post
    Cheers, Murray
    G'day Murray have you got any specs on them spacer blocks as i've got the same twin filter set up to go on my county .
    Dayboro, Qld
    My 4BE1 engine has the twin filters fitted, but has no spacer blocks. You'll be able to have a look on sunday at "The Defender Day" if you wish to
    Thanks Murray.
    Yep looks the same.
    I thing it is about 25mm too long for my bump stop space.
    Are you planning to make anymore spacers in the next 12 mths. I have enough top mt oli filters til then.
    Peter
    Cheers, Murray
    REMLR # 137
    SW of Geelong
    Quote Originally Posted by lokka View Post
    Quote Originally Posted by rar110 View Post
    Thanks Murray.
    Yep looks the same.
    Peter
    The above pic is the basic dimensions, but if you're running a turbo you'll need to allow for the oil feed to connect to the top spacer (see pic below).
    I had a mate mill these up from steel, but if I were to do it again I would make them from aluminium. I'm not planning on making any more at the moment, but I will be keeping an eye out for any aluminium billet I might come across.
    I made mine 50mm thick, but 60mm is what they need to be to clear the bottom filter on the prop shaft yoke at full articulation.
    Cheers, Murray
    '56 SI Ute Cab
    Thanks, will do, which 110 should I look out for?
    Quote Originally Posted by jerryd View Post
    REMLR # 137
    WA
    Another option is to get Adam (Agrojnr) to lasercut some for you like he did for Offender90, Inc and myself.
    He can only cut up to 15 mm, and he said the distortion is less if they are 12mm, so you need to sandwich 5 plates together for the bottom one, but not a big deal.
    Just use phosphoric acid to remove the mill scale from the plates, give them a light sand on a sheet of glass, then bolt them up with a smear of rtv/silicone between.
    Thanks for the offer Jerry. The day went pretty quick and I didn't get a chance to have a look.
    REMLR # 137
    I had a very quick look at Inside's Perentie on Sunday. I think it may have a 6x6 motor fitted with a twin filter setup. The twin filter and oil line had spacers fitted which looked like cast alloy. The bottom spacer had an AYG???? part no in raised lettering/numbering.
    Anyone heard of this?
    REMLR # 137
