Results 1 to 10 of 12
Thread: Did you ever get stuck because of the immobilizer or BECM/ECM synch?
    Dec 2008
    Paris, France
    Exclamation Did you ever get stuck because of the immobilizer or BECM/ECM synch?
    Guys,
    I'm asking you in order to know if the Australian Market Reprog of the BECM that i do are a way to make the P38 more reliable.
    Looks like you don't have any EKA code to do in case you remote do not work.
    Please tell me!!
    Flo
    Mar 2009
    Bexley NSW 2207
    yes in some situations the Aus spec program with no is EKA is a prblem. if it was locked with the remote it can only be unlocked with a remote (so i reprogram them to have an EKA). on the very early models we had a self relock feature aswell, if you unlock the car and do not cycle the ignition the car will relock by itself, this is very annoying when you have left the key on the dash will you are working on the car.
    i have seen other programs that have more user friendly arming and disarming. landrover programed a becm as a test unit that could be locked with the remote and unlocked with a door key, when i looked at the actual coding data every one of the 40 lines was different. there was also an after marked company who used to reprogram them differently here in Sydney but i think they have gone now.
    regards
    Rupert
    Yes, I have lost synch between BECM and engine ECU
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    Dec 2008
    Paris, France
    Quote Originally Posted by Rupert Prior View Post
    regards
    Rupert
    Hi Rupert,
    May you tell me how you can program back EKA? How do you know the code then?
    Florent
    Mar 2009
    Bexley NSW 2207
    hi Florent
    when the Becm is new or cleared or just unlocked it can the have the programing changed. if you have a suitable scanner you can enable the EKA and it will ask you to pick a 4 digit number.
    regards
    Rupert
    My early '95 model has no EKA. I can unlock it with a plain key even if locked with the remote.
    Providing I open a door or the tailgate, the car doesn't relock.
    Mar 2009
    Bexley NSW 2207
    hi Ron B
    i`m working at getting mine to work like that.
    the only time mine did that was when the remote was faulty and not fully resynchronised.
    do you know much of your cars history?
    regards
    Rupert
    Douglas Park, NSW
    Ditto with my '96.
    Dec 2008
    Paris, France
    hi Florent
    regards
    Rupert
    Hi Rupert, i use a Testbook T1. I'll try that on a good day.
    Dec 2008
    Paris, France
    No matter what the condition the BECM is it can have the settings reprogrammed with a Testbook.
    I do market changes (Australia very often) and i select EKA passive to finish the job.
    Programmation of new accessories (cruise control, foglights, trip computer, electric seats). Yes there are some people that update their low line P38s here with luxury items from DSE (2.5 diesel high line) and HSE's
