Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: L322 Ability Off Road
    Jun 2008
    Hi,
    What is the general consensus on the 'offroad-ability' of the L322, particularly the TD6? Is it a capable getting out and about in the Australian wilderness..
    A friend thinks that it would 'not have enough clearance', but doesn't it have similar off road suspension settings to the D3/D4 and Rangie Sport?
    All thoughts comments and any first hand experiences welcome
    TIA
    2R
    Safety Bay
    I have a Td6 and the traction control is very good,actually it's bloody good.They are too low,I have to pick my lines early when going over ground my defender will do on it's ear and I've had three through the tread punctures running continental tyres.They are very neat underneath,nothing hangs down and nothing is in a position that will cause it to be hit unless you really try hard to do it.I really like the room,they have enough space for five adults with thier bags,they are very quiet,smooth and I get very good economy,mine did Newman to Karratha and back last weekend and it got 9.5ltres per 100 sitting on 120k's/hr.All over they are good,I would and have taken mine over some rough ground but I'm fitting it with harder tyres when the conti's wear out,service costs are cheap,all over running costs are cheaper than my 08 hilux I had.Fitted with Michelin tyres I would take mine anywhere across WA,I just wouldn't go to the really hard rock hopping type tracks. Pat
    May 2010
    cairns
    I have only had mine since May. In the deep north its very wet tracks that we have to contend with. I am amazed at the ease that the L322 does it and a very smooth ride. I can compare with a ML and Cruisers that I have had over the years.
    For super rough stuff had to beat a Cruiser ute but other than that these heavy machines do it very well.
    Jul 2008
    Cheltenham, Vic
    Comparing specs on the brand new models:
    Range Rover Vogue off road height clearance - 283mm
    D4 off road height clearance - 310mm
    Range Rover Sport off road height clearance - 227mm
    Would expect the older L322/D3/RRS to be pretty similar to the new ones.
    I haven't had any clearance issues on the rare occasions we have taken the L322 off road but tyres are definitely an issue, especially on the 19/20" wheels - best to stick to the 18" if you want a reasonable selection of more off road biased tyres.
    Al
    Safety Bay
    In Newman rocks are an issue,I drove down a creek bed two weeks ago to get to a waterhole and mine scraped a few times.The only issue is you can't fit taller tyres,but then again thats why I have the defender.All up they are a class act. Pat
    Quote Originally Posted by ariddell View Post
    Al
    I am surprised at the lack of ground clearance of the RRS given its Disco origins. I can see that figure in the brochure but wonder if it is a misprint. My Freelander has 210mm (measured) and it gets slammed for poor ground clearance so if true - the RRS is not a lot better.
    I have seen some nice looking tricked up L322s on US forums so work can be done on them if required. I have seen standard L322s offroad ans invariably performed better than standard cruisers etc.
    I think if you are looking at offroad then a close look at tyres would advised.
    Safety Bay
    The biggest trouble is if you do alot of open dirt road cruising like I do you can't run at anything but normal height or you'll wreck the tyres.Washouts and ditches etc across the road means stopping and setting the height,crossing then lowering again.Still I wouldn't sell mine for anything else. Pat
    Queensland
    Hi 2nd Rower, the earlier L322, the TD6s are fantastic oof road and with a decent set of off road tyres, I doubt that there would be too many vehicles that could compete with it.
    They are great on and off road and there's lots of genuine and after market accessories available for the earlier L322 RRs.
    The V8 diesel versions, the later model L322 are the greatest waste of space ever made and is nothing more than an over rated over priced under performing Pimp Mobile, a puss box special.
    If your after a great off roader and a fantastic on road long distance cruiser, you can’t beat the TD6. It has more room inside that the newer RRs and the seats are bigger, so more comfortable, particularly when off road.
    Plus with the way they have devalued, they will now hold their price.
    Jun 2008
    Many thanks for all the responses! It's good to hear that there's a general positive consensus.
    I think I would be looking at a TD6 for the longer range on a tank. There don't seem to be that many on Carsales.com.au, is there a better place to look.
    Also what are the risks of taking a high KM (e.g. 170km's+) example versus one that is low km's (e.g. less than 100km's).
    Lastly is there a source of knowledge on the different model variations and spec available in Australia (SE vs HSE vs Vogue), and also the options such as "Driver convenience pack"?
    Manly QLD
    After going through this early in the year and purchasing a mid-2004 td6 this is what I managed to find out. Here goes.
    MY 03 (pre aug 04)
    Vogue over HSE.
    Nav system, 12 speaker ICE, 19” wheels, Bi xenon head lights, Heated Steering wheel, heated seats (all), “comfort seats” in front.
    Vogue Options - Met paint, integrated phone.
    HSE over SE
    11 Speakers instead of 6, Driver's Convenience Pack (auto wipers, parking sensors, exterior mirror mounted approach lamps, power fold mirrors, Memory drivers’ seat +mirror and column, load space net, duel sun visors), Auto Dimming rear view mirrors (all 3), Sunroof, CD changer.
    HSE Options - All the Vogue extras EXCEPT “comfort seats” and the 19" wheels were V8 only
    SE options - All the HSE and Vogue extras EXCEPT “comfort seats” and 19”wheels.
    All SE vehicles I looked at had no extras at all.
    As an addition to above - I found the 2002 / early 2003 HSE models had the sunroof and Driver's convenience pack as an option, they all had driver’s memory seat but the rest of the pack listed above wasn’t there on many of them. And it also appeared that if the sunroof was there the full pack was also.
    There was an update with build date of around August 2004. Post this date is MY05, major difference was the gradual replacement of all computer systems, replacing the BMW ECUs with Ford – yes there is actually 2 bus systems for the MY05 and diesel MY06. And the replacement was gradual – good luck trying to work out what systems you have.
    Terrain response was never installed in a TD6 car, in the petrol varient of MY06 the V8 BMW engine and all BMW ECUs was replaced with the Jag engine + 6 speed including terrain response and Ford ECUs where diesel varients gained new trans with the TDV8 (MY07). MY06 on - the Range Rover was renamed Range Rover Vogue (introduction of Range Rover Sport) with only one spec, these vehicles most obvious changes are updated headlights, bumper and grill and the extra AC vents in the top of the dash.
    hope this helps...
