Did you over fill the transfer?
There is a gasket on the output shaft seal retainer, but the most likely places for it to leak are the hole for the locking pin for 4WD or the hi-lo selector shaft. there is no "O" ring on the selector shaft and with wear it is a place for oil to escape if the t/fer box is overfilled.
