Can you post a pic of what it should look like...
I'd guess I can get it pretty cheap for you
I want to have a rant here, but am unable to name and shame.
In the process or returning a torsion bar to the front of Gog removed by a dealer/wrecker in Victoria, parts have to be acquired. Unfortunately because of the nature of the relative rarity of the SIIB some bits are difficult to acquire.
You can imagine my surprise when I found the rubber bush to support the torsion bar to the chassis listed in one of the usual UK suspects catalogue. (No not Blanchard or Dunsfold) There it was 552418 with a superseded to 552418P a urothane replacement - even better I thought. So I paid my money and waited and waited, they had told me they had to have it manufactured. Several months later I contact them again "what's happening?" I ask. "Didn't you get our reply" came their answer. So a couple of weeks later the item arrived.
I sit the urethane bush on my desk, looks the right shape, so pick up the retaining strap to fit it in. Oops the OEM strap is 38mm wide yet the groove in the bush is only 29mm (38 into 29 doesn't go).
Then I look at the bore. They have a 17mm bore to support the torsion bar, yet the torsion bar is 22.5mm. While rubber may compress 5.5mm doing the same with a urethane bush is a different matter.
So I contact Penny and tell her of my problem with their product and the reply comes back: "Thank you for your e-mail, Mark from our Export department has said. 552418P are as supplied 17mm, NTC6828P bushes are 25mm, But are all 29mm’s wide."
I don't want any NTC parts I want a good old Rover part 552418 and I want it to fit - doesn't anyone care about proper customer service any more?
Does anyone know someone who makes poly-urethane bits?
I'll post up an image when I get home from work tonight.
It was reasonably cheap from the UK too but when they aren't correct, they are too expensive.
It is basically the same as the rubber/polyurethane bushes for most of the other torsion bars. a round top, flat bottom, a hole with a split to insert the bar and a groove going over the round top into which the retaining saddle fits. The main difference is the saddle is 38mm wide instead of 28mm of the RRc/Disco 1/Defender types and the bore is to fit a 22.5mm torsion bar instead of an 18mm or whatever the others are.
BTW: what do the NTC6828 bushes fit and how thick are their torsion bars?
I would expect SuperPro would make something of an appropriate (or very close) size.
As you would know - just about every thing on the 101 is different to the other landies yet parts dealers are always telling me I am wrong so I always double check.
With my rubber bits I have never had much luck sourcing the correct bits locally at a reasonable price - where I have found considerable success is hitting the local truck parts suppliers - the non dealer ones. I got all my shockie bushes in nylon as well as my roll bar bushes - all generic small truck parts. Matched to a sample.
So give them a try.
Good idea Garry.
It was just when JC's had the Rover part number in their catalogue, you would expect it to be the same as the Rover part.
The bushes I used for the ends of the torsion bar on Capt. Pneumo came from a generic pack of polyurethane suspension bushes I found at SupaCheep, I was going to do the same on Gog!
Yes; Penny seems to have dropped her bundle recently. I sent her an email asking for more information about a part with explicit questions and she sent me the same blurb to be found on the website
Mind you at least she responds to email, unlike the mob that remind me of pasture.
It may not help, but the bushes you have could be made to fit by boring or drilling the hole to the right size and hacksawing them into halves and adding a urethane spacer. Mind you this would only be worth doing if you can't get proper ones from somewhere else,
Cheers Charlie
