Results 1 to 10 of 19
Thread: RRS Ground Clearance
    In the L322 section they have indicated that off road clearance of the RR, RRS and D3/D4 is as follows
    Range Rover Vogue off road height clearance - 283mm
    D4 off road height clearance - 310mm
    Range Rover Sport off road height clearance - 227mm
    The 227mm for the RRS seems low as it is a D3/D4 underneath but I have confirmed this in the brochures - is this a misprint? I guess not.
    So does anyone know if the RRS offroad height clearance can be modified to that of the D3/D4 and what is required.
    Canberra, Australia
    Garry,
    At the LRExpo this year Bruce Davis had an electronic box that could be used to change the 'standard' heights for the RRS, D3 & D4.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    St George Dragons Territory, NSW
    Check out this thread which relates to a guy on the forum who seems to have developed a controller that allows different heights to be set and effectively "off road" height to be maintained above the 50kph.
    http://www.aulro.com/afvb/verandah/1...d3-d4-rrs.html
    i believe it is being distributed via Bruce Davis.
    George
    Thanks guys but that is not the issue. That system allows you to select various height settings within the design parameters of the vehicle.
    The issue I have is that a RRS on its offroad setting is a full 83mm lower than a D3/D4 and they are supposedly the same vehicle underneath. So logically a RRS should be able to get to 310mm when offroad.
    With only 227mm, a RRS will not be able to go many more places than my old Freelander will go if ground clearance is a limiting factor.
    Mornington Peninsula
    As far as I know the offroad height of the RRS is only slightly less than the D3/4 due to slightly smaller tyres. Having both an RRS and D3 I can vouch for that.
    Sydney, Australia
    The RRS has different suspension geometry which probably accounts for the difference in height. The ramp over angle is about the same as the RRS has a shorter wheelbase.
    If you wish to raise the height in all settings you could install shorter suspension rods but that would compromise the on road handling.
    NSW SW Slopes
    Maybe 227 should be 272, which accounts for the tyre size difference.
    NSW SW Slopes
    With a Llams unit, the vehicle could be jacked-up front and rear at calibration time when at off-road height to provide a higher Llams off-road setting. How high would you like off-road height? Normal height would not be affected.
    Yes but the maximum you can ever go is 227mm (as that is the max built in available height) not anywhere near the Disco 310 mm. No amount of tricking it will make it go higher as it is a physical limitation. To me 227mm is just too low for any serious offroading.
    Will D3 airbags etc give better ground clearance as I though the suspension geometry was the same as a D3.
    Sydney, Australia
    If 227 is the off road height it is not the physical limit. There is still extended mode and super extended mode. On the D3 there is not a lot beyond that, don't know about the RRS.
    We put the air actuator system on a RRS which gave it 35mm extra lift.
    The Llams system would be similar but Graham would know what happens with the RRS.
    I think you will find some serious off roading is done with a RRS straight out of the box.
