                                                26th November 2010, 07:13 PM
			Tyre Pressures
					Can anyone help with tyre pressures on my 200TDI 110 Wagon?
 I have the big, slim 7.50 R16LT Bridgestone 693 Duelers. The tyres themselves give stats for cold pressure at 65 PSI which I assume is too much and can't find any pressure guides on the vehicle anywhere?
 Any help appreciated.
                                                26th November 2010, 07:24 PM
			Reply fender 22
					G'day fender 22.The tyre pressure for the 110-750x16 tyre is 28psi front 48  psi rear,normaly most run them at 36psi all round.There should be a tyre chart on one of the rear pax door cut out.Hope this is of some help.Cheers Lochie
                                                26th November 2010, 07:28 PM
					i ran 38 front 40 rear when i had 7.50 16's
 and run the same pressures with my 235/85/16 BFG MT on the front and 238/85/16 BFG MT KM2's on the rear, just fitted the KM2's on the rear tonight and topped up all tyre pressures
