Results 1 to 10 of 11
Thread: Rim Size
    zoomi Guest
    Red face Rim Size
    Newbie question.
    I would like to put some sunraiser style rims on my 2A. What size would I go for to make a swop from standard rims.
    Also the Gal brightwork all aroung the Landy is old and tarnished, has anybody got a good remady to perk them up.
    Ron
    Oct 2010
    I've just bought a Series IIA with Sunraysia style rims on but I don't pick it up until Thursday morning so it'll be a few days till I can tell you what's fitted. Maybe someone else will have been along to help you before then.
    Ciao
    JayBo
    Ipswich QLD.
    Scotch Brite (the green scruber things) and water brings the Gal bits up nicely.
    1970 109" Series 2A G.S.
    1959 88" Series 2 C.R./G.S. Forward Area Ambulance
    1997 Discovery V8
    Oct 2010
    Hi Ron.
    The tyres on the S2A I bought the other day are 31/10.5x15" but I haven't managed to get home in daylight to see if I can see the actual rim dimensions. At the moment I'm assuming they're 15x7 rims but they may well be 15x8. I'll let you know when I get a look in daylight in the weekend, as under torchlight I have not found the wheel sizes stamped on the rim outsides. I suspect I'll have to take a wheel off and check the inside.
    I do know that the bonnet spare is a 7.50x16" and it looks like the wheel will be a 16x7. I'll try and confirm that for you too. The circumference and rolling diameter of the two different tyres are basically the same so no real issue with either sized tyre.
    John B
    Meredith vic
    rim size
    Quote Originally Posted by JayBoRover View Post
    Hi Ron.
    John B
    Series wheels are as follows; SWB 5"x16"
    LWB 5 1/2"x16"
    7.50x16 tyre have a nominal diameter of 32" depending on the manufacturer, 31/10.5x15" have a nominal diameter of 30" so do not mix them on your car! A series landy will steer and drive much better on the 7.50x16 tyres and the steering is much lighter.
    Series 11 & 11A FC have 6x16" wheels with a greater offset than normal, Same as the S111 one ton. English LWB rims have a greater offset too.
    Discovery steel wheels are 7x16"
    Jan 2008
    Goodna QLD
    Be aware that there are many different sunrayser style rims with different offsets. I bought a 2A 88 with 3 different rim offsets (tossed them) and they differed by 30mm or so.
    Quote Originally Posted by zoomi View Post
    Newbie question.
    Ron
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by landrover dave View Post
    LWB 5 1/2"x16"
    Just to clarify:
    Forward control rims are 6 1/2" and there are only SIIa and SIIb forward controls no Series II.
    There is also a 4 1/2" rim on the 1948 model Land Rover and are identified by the lack of markings on the outside and also the different position of the valve stem.
    The different offset sunraysia rims are usually the Range Rover and the Series Land Rover offsets - there are also differing width sunraysia rims.
    thanks for this post Diana I reckon this might help me to identify some of the many series rims I have
    Jul 2010
    Birmingham England
    if any of your rims have ANR1534 stamped on them they'll be the 127/130 rims
    that's the only one i know as i bought a set to put on my 88"
    1.20 MB
    Thanks NiteMare
    I haven't updated the digramme lately as there are two variants of 130 rim. The early type used on the 120/127/130 is displayed however there is a later type with a positive offset. Then there is the Wolf rims and the tubeless rims.
    The Defender rims are easily identified by the D> makers mark and the fact that the 6.5" rims have a broad flat about 2.5" wide, where the series FC rims have a broad flat that is 3" wide.
    Once I have confirmed the rims against the numbers I will modify the diagramme.
    Diana
