                                                8th December 2010, 08:48 PM
			TDV6 Header tank
					Has anyone changed the header tank for the radiator on a TDV6?
 was wondering if there is much involved in it, as mine has droped the
 sensor to the bottom of the tank and keeps coming up with
 LOW COOLANT fault. Dealer said the only way to fix it was a new tank.
 Bigmac
                                                8th December 2010, 09:35 PM
					I'm sure the headlight needs to come out then the tank can be replaced. It can't be too hard as book time is just under 1/2 hr.
 Not that it's a common fault though.
 L87
 261501
 0.40hrs
 My head hurts . .
                                                9th December 2010, 06:29 AM
					Very common fault. Float ball takes on water and sinks. Mine was replaced under warranty no problems with new one.
                                                12th December 2010, 08:36 PM
                                                #4
					Changed the tank today took about 20 minutes and $77. for the new tank
 Headlight does not hve to come out, pull power steering bottle off just slides up,
 unclip neck of washer bottle, undo the top hose undo two bolts that hold the tank
 on and lift up to get at the bottom hose and the sensor. The sensor has a wire
 spring clip on it that slides down before you can pull the plug apart.
 Bigmac
