Results 1 to 10 of 19
Thread: Wheel Nut Indicators
    What's people's thoughts on these? I'm starting to think for my use they could bring some piece of mind. My 110 isn't a daily driver, and it's use will likely be short to long trips over varying terrain with often a long time between trips. These indicators should cost less than $20.
    It makes me wonder why tourers and hard off roaders aren't using them more. Maybe because they don't look cool?
    Below some info I've gathered:
    Nissan Patrol Y61 Alloy Wheel Fitment Service Campaign | Australian 4WD Action
    Checkpoint Safety - Australia - Checkpoint
    Watch the video here Wheel Check | Loose Wheel Nut Indicator, Wheel Safety Indicators
    Safety Bay
    Buy a torque wrench and torque them to the correct amount. Pat
    Central Queensland
    speaking for myself, with the number of them up here, i take great delight in occasionally moving one around a notch or two when i see them on the mining vehicles up here
    as for the OP...... people survived for long enough without them..... i'm sure you will prove no exception
    Loose wheel nuts on Defenders are quite uncommon (due to the large PCD and large wheel stud diameter), and are invariably due to incorrect tightening or tightening with dirt between the wheel and hub. While a torque wrench is the ideal way of tightening them, this is not really necessary; if tightened correctly they do not come loose - ever. (In fifty years of driving Series Landrovers and 110s I have had exactly one case of a loose wheel, due to my failing to remember the final tightening after lowering the jack on a front wheel.
    Consequently, I would regard them as complete waste of money. They are perhaps more useful on those vehicles with smaller studs and smaller PCD - I have had problems with persistent loosening of wheel nuts on some other vehicles in the past, especially IH 120/1200.
    A more common problem is overtightening by tyre service places, and it is just possible that they may deter them!
    match mark them with a paint pen after you tighten them up with a torque wrench.
    paint pens are about $8 and do a whole lot more besides and the marks dont fall off or get moved.
    ..... nor stolen. I've had valve dust caps stolen so I reckon these would go, too (as would the new tyre pressure monitors attached to valve stems).
    Lake Macquarie. NSW.
    I drive buses for a large bus company in the Hunter Region and after a wheel fell off a school bus a few years back caused by loose wheel nuts, Wheel Nut Indicators are now used on all buses in the fleet. It makes it easier for the driver when he is doing his vehicle check before driving the bus, to notice if a wheel nut has moved. I believe they should be used on all heavy vehicles.
    Having read the above posts I think it is a personal descision to use them on light vehicles though!!!
    Moruya Heads/Sth. Coast, NSW
    I don't believe large studs or large PCD has anything to do with greater safety or less chance of losing a wheel through wheel nuts coming off as stated by JDNSW, if you look at the majority of wheel losses, most of them are on trucks with enormous studs and PCD.
    However I do believe dirt, corrosion and crap (JDNSW) behind and between wheels is a major cause of wheel nuts ending up loose.
    My Son lost a wheel on his 94 Disco returning from Bendethra, with some spare nuts he refitted the wheel and drove home, not telling me of this incident resulted in the same wheel coming off while I was driving it.
    The cause was alloy corrosion on the back face of the alloy rim and rust explosion on the hub.
    I actually needed a disc grinder to remove all the crap and a file to touch up some areas, so I pulled all of the wheels and it was only the one that came off that had the buildup of corrosion.
    I reckon what happens is that the wheel nuts tighten the rim to the hub with a pile of crap between and a few miles down the road the crap either compresses further or is vibrated out from between the rim and hub, leaving the nuts loose, leading to the wheel eventually coming off, Regards Frank.
    South Yundreup,WA.
    They have their pros and cons. We have them on our emergency vehicles, but it all comes back to pre start checks and if they are done correctly. The biggest problem people are just lazy and dont do pre starts properly. It would depend on cost wether they are worth while for general use.
    A friend has a late model Nissan and Nissan has mandated they be fitted as he has had several issues of the wheel nuts coming loose, after servicing.
    These may not fit alloy wheels either.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Loganlea Qld
    Way back in the dim dark past of my coach operational days, we were unfortunate enough to lose a set of duals from the rear of a 1625 Mercedes Benz coach and these wheels jumped over the coach (according to an eye witness following the coach at the time), bounced twice then one rolled off into the wilderness and the other continued on to demolish a small motor car heading in the opposite direction. It collected the oncoming car just behind the "B" pillar and totally wrecked the rear right hand side of the vehicle. The car was occupied by a youngish mother in the front seat and two smallish children in the back, who luckily were breaking the law of the land and NOT wearing seat belts and both leaning over the rear of the front seat on the passengers side talking to Mum at the time of the impact. Neither was even touched!
    The driver of the coach (a coach owner himself) had checked the wheel nut tensions at the last stop (Midday) and adjusted the tension on one of the wheels.
    One and a half hours later the left hand rear wheels came off!
    In this particular case those wheel tensioner check doohickeys would have been absolutely useless as they would have shown correctly at the last check.
    (All our drivers were under instructions to check wheel nuts every morning before a shift and again at lunch break, but in the particular case mentioned above, even this wasn't enough.)
    Lack of tension can be your enemy.
    Too much tension can have the same result by stretching studs.
    Dirty threads and wheels is a major problem, and the list goes on.
    Read you handbook and comply with the instructions and don't put your faith in gizmos!
    Glen
    1962 P5 3 Ltr Coupe (Gwennie)
    1963 2a gunbuggy 112-722 (Onslow) ex 6 RAR
    1964 2a 88" SWB 113 251 (Daisy) ex JTC
    REMLR 226
