Results 1 to 10 of 14
Thread: Missing Gearbox Mount?
    Jun 2010
    Was crawling around underneath the truck this morning checking driveline slack and noticed this.
    Now cut my legs off and call me Shorty but to me this looks like there should be a bush supporting the gearbox in the gap. Hole in the bracket lines up with the thread in the box..the only thing missing is what I would expect to be a rubber bush and a bolt to bring it all together. Or is this just another Defender "quirk"?
    Nope ment to be like that question has been asked Sooooo many times .
    We have all been concerned about that, one after the other
    Jun 2010
    That looks soooooooooooo wrong!
    Ive found out something about it...
    ITs an aux mount for when you change the gearbox mounts...
    slide a bolt into it, drop on a washer wind on a nut, screw it up into the box then wind the nut down the bolt and it holds the gearbox in place while you change the mounts.
    dmdigital's Avatar
    Looks like you finally crawled under the Puma for a good look
    Now can you explain why it is so clean under there?
    Jun 2010
    Actually I thought someone might ask why I had'nt gotten all the sand off from being up the beach last weekend!!!!
    Was supposed to do some real 4WD'ing today but has rained all day..will try to pick up my game!
    Brisbane,some of the time.
    Quote Originally Posted by nugge t View Post
    How is the friggin rain,will it ever stop?
    I recon that mount is for when the ZF option comes in with the update model
    yeah cause theres something that belongs in a deefer.... an auto..
    Im stunned enough to learn one of two things from this.
    1. Ford thought far enough ahead and decided to make something thats a routine repair easy for the owner
    OR
    2. Ford had no faith in their workmanship on the Tcase or the mounts so made it easy for the mechanics to do warranty work.
    Jun 2010
    Got that right!!!! We were going to Glasshouse to put the D through its paces but a waste and dangerous in this weather. Looks like it has set in for the long haul unfortunately.
    Avoca Beach
    I am afraid I find it difficult to believe that Land Rover would spend several dollars per vehicle to cast a mount into the gearbox, set up a drill press to drill and thread the mount and fabricate a mount on the crossmember for the convenience of warranty or mechanic work.( especially since the threding of the gearbox mount would not be necessary for that purpose)
    AFAIK they or any other car maker would not spend money for that purpose.
    I believe (based on 20 years in the industry) that they designed the mount to be used but for some reason decided not to use it, most probably NVH. ( or maybe it had unforseen effects on some other component found only in late testing)
    Someone out of warranty fit a suitable mount there and see what it does.
    Regards Philip A
