There are quite a few places oil can leak on the rear axle, is it a Sals? what year is the 130? If it is leaking from a crack in the housing etc he is quite possibly in serious trouble, but a hub seal onto brake disc, or a pinion seal leak he can top up and get out of there, providing the leaks arent caused by failed wheel bearings, or a failed pinion bearing.
More info would help us. Infact if he has facility to ph or txt at some point he can contact me diretc on 0408 995 635 and i can possibly help over the ph. Just not too early, or too late at night
JC
