is the 2.7TDV6 availabe as a manual? if so what manual?
im heading towards the TDV6 even an auto would be good if it can be mated to an lt230...
Im thinking it will be shorter so can sit back against the bulkhead better and cheap the weight more towards the middle. No idea but would it be shorter than the TD5 due to beeing a V formation...which would keep the center of G lower....but then the TD5 may weigh less which would change the equation also...
Id like the new TDV6 3.0 if you can please
