Results 1 to 3 of 3
Thread: TD5 Defender - strange transmission noise
    Garfield, Victoria
    Hi All,
    Just recently I am experiencing a high pitched, "sizzly" noise coming from the gear lever area in the Defender. It is sharply centered on 60Km/hr, and it is audible in both 5th and 4th gears at this speed. A few Km/hr either side of it and it more or less disappears.
    It is almost as if a grommet is loose somewhere, but I have not been able to see anything obvious.
    As in all Defenders, there has always been the normal whine from the transfer box, but this seems to be a new noise, although outside the narrow band around 60Km/hr noise levels seem quite normal.
    Any ideas?
    Lionel
    Sydney, NSW
    It might not be of any use, but I once had a TDi Defender with a failed centre exhaust section, made exactly the same kind of noise.
    Could have sworn it was a gearbox issue and spent hours trying to track it down.
    In the end it was the inners of the muffler rattling about!
    Regards,
    Jon
    South Yundreup,WA.
    I have the same in 4th gear at about 80kmph. Sounds a bit like a tin rattle.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
