Results 1 to 10 of 20
Thread: D2 Horn buttons
    Jan 2011
    Dry Creek NSW (Upper Hunter)
    D2 Horn buttons
    My (careless) D2 has lost one of the plastic horn buttons from the steering wheel. I offended her with the application of duct tape to hold in the spring and metal plate.
    I thought these must be a pop-out/push-in easily replaceable item, but I am informed that these come as part of a kit including airbag and sundry....at considerable expense. The duct tape gets to stay for the moment!
    Has anyone else had this problem?
    Mar 2009
    Port Stephens N.S.W
    There's a US seller on Ebay with some aftermarket buttons ! About $40US/pair I think it was.
    Buttons have been specially made to solve your problem. Noticed them the other day. CRA Custom Rover something maybe ?
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    at the foothills of the Dandenongs. Vic.
    if you can find it, its easily fixed - mine has stayed together for 2 years. Cut a piece of rubber from a thong that will slide down the centre of the spring and is 3-4 mm longer. silicone each end, attach plastic horn button, bingo. Good as a bought one.
    Tamborine Mountain
    Quote Originally Posted by dinosaur View Post
    Ahh ha hahar, Thank you will do tomorrow
    May 2003
    On The Road
    I dunno,, if it was anything but my thongs,,
    Quote Originally Posted by Fluids View Post
    Search for seller customrover
    item number is 260685711793
    CRA stamped in thems a bit naff though.....
    Mar 2009
    Port Stephens N.S.W
    That's them!
    Thanks Andrew
    Kev..
    2008 Isuzu D-Max
    Jan 2011
    Thanks All
    Will look at the Ebay option.....
    Would LOVE to try the thong solution - but alas the button has disappeared....
    Thanks again for suggestions and I am pleased to see that I am not the only one..... Regards
    I thought I saw in microcat the set of two buttons that came with just the wiring etc for both sides. Wasn't listed with the airbag assy. Was looking as one of the clips on my RH button has broken off and if not careful ever now and then it pops out. Don't have microcat on me at the moment sorry.
    Hamish71 Guest
    You can get the genuine part from brit-car.co.uk for about 45-50.
