Thread: Marumi filters OK?
    Brisvegas, QLD
    Marumi filters OK?
    Hi guys,
    DWI sell Marumi filters, are they OK? I just want a UV filter for lense protection, and they sell a Marumi "DHG Lense Protect UV filter" for $27. I may be purchasing a Canon L series lense, so for that kind of money I don't want to diminish the image quality by putting on a crappy filter...
    Sean
    Sunshine Coast
    I haven't used them. I would have a guess that they are not top quality though.
    I don't use UV filters. If you use lens hoods and are generally careful shouldn't have to worry.
    Otherwise should go for Hoya HD / Pro
    Singh Ray and B+W Schneider are the best of the filters IMO. Hoya is next second choice. Marumi aren't a bad product either.
    The issue is whether the filter coating will match the lens or not. In some cases this can be an issue. Also you really only want a protection filter, you don't need a UV one as the camera's sensor has a UV filter built in to it.
    I use a couple of Marumi filters and they seem ok to me. But then, I doub't I'd notice the diff
    Brisvegas, QLD
    Ended up ordering a couple of Hoya filters ... along with a EF 70-200 F4 L $$$$
    Sean
