Results 1 to 10 of 16
Thread: Overdrive identification
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Can anyone identify the overdrive fitted here, purely from inspection of the knob?
    It has On<->Overdrive<->Off written on the top of the knob.
    Thanks, Peter
    WA
    Crawl underneath and take a pic of the overdrive unit. They are very easy to ID from the casing.
    Aug 2010
    Western Australia
    Sounds like it is a Toro overdrive. I have one in the shed, looks similar in appearance to a fairey unit.
    WA
    Quote Originally Posted by andy_d110 View Post
    That selector looks nothing like the one my Toro had.
    East-South-East Girt-By-Sea
    1.20 MB
    But it looks exceptionally like the knob of the Fairey overdrives.
    WA
    However there is no way of knowing if someone has been mixing and matching selectors or ODs.
    I was going to ask how did you arrive at that conclusion but others have beaten me too it.
    1.20 MB
    Ben
    Can't agree more - but I did suggest that the "knob" appears exceptionally ...
    Feb 2009
    So here's some pics of the beast . . .
    Peter
    Jul 2010
    Birmingham England
    the only thing i can tell for sure is that my Fairey O/D has a proper hex head drain plug, whereas that one looks to have a tapered plug
    it'll probably be best if you lift the centre seatbox cover out and look in there to see if there's any writing cast in (name), if there's not then you are left with removing the O/D and looking at the clutch sleeve splines
    Fairey splines are quite fine and fragile looking and are still obtainable (although expensive), Toro clutch sleeve has quite chunky teeth and parts are VERY difficult to find
