Results 1 to 10 of 21
Thread: Panel beating - Can this one be done?
    Yanchep, WA
    Hi All!
    Have just found a replacement D2 that fits my budget nicely. Down side is that it has a bit of a dent from being clipped by a bus.
    Any suggestions on where I can get this fixed up properly around Bris? Also any idea of cost? If it's too expensive I might just live with it.
    I'm inspecting the vehicle next weekend with a view to buy. Annoyingly it's in NSW and I'm in QLD.
    Wil
    Discobaker Guest
    They may be able to get inside the guard to repair it if they only have to take the rear most damaged panel off. Should be able to get it pretty straight again but I'd think if they have to remove the entire quarter off it'd become costly in labour terms. If you go with it & get it repaired, maybe request some progressive pics of the job so u know what's going to be underneath the paint on completion
    Cost, I'm not sure, get a few quotes & decide from there, in my experience there can be some massive differences from one end of the scale to the other. Looks to me like it's all panels damage rather than internal though which is good
    Hope I've helped rather than confused
    Jan 2010
    Australia, VIC
    that is purely cosmetic damage, but the problem with repairing that is its made out of aluminium, so unless it is sent to a workshop that has the proper equiptment to weld a plate to the aluminium panel and pull the damage out, then the only other way to fix it properly is a new quater panel,
    from memory there isnt alot of access behind the trims in that area, but having said that it has been a while since ive done a smash repair on a quater panel of a series 2
    Discobaker Guest
    Quote Originally Posted by Pauly85 View Post
    Most P beaters use mig now I'd think so it's just a matter of if they have aluminum wire & the experience I guess
    Jan 2010
    Australia, VIC
    yeah you can get aluminium migs, alot of panel shops out there dont have this equiptment still
    we have a machince called a 'mig brazer' also called 'silicon bronze' with a secong lance which we can run aluminuim though it
    a traditional mig welder is no good for aluminium
    Avoca Beach
    Wouldn't you just whack it in a bit and bog it?
    Seems a lot of expense to go to for a little cosmetic damage.
    Regards Philip A
    Jan 2010
    Australia, VIC
    yeah you could do that, just depends if he wants it fixed properly or 'dodged up'
    For a quick and dirty DIY you can work the crease/bump out using a slide hammer but you will need to use welded or L shaped pullers as expanding screw in type will just pull out of alloy. Alternatively pull off the panel and hammer out with a dolly behind. Then bog and paint.
    Crafers West South Australia
    You may be able to push a piece of wood behind the damage from underneath. Shape the piece of wood to fit. Undo the mud flap bracket for access. When in place gently tap down the high points. Also pull out the tail light and push from inside there.
    Nov 2007
    home at last - Port Macquarie NSW
    or back into a bus and claim insurance repair
