 Originally Posted by
Ratel10mm
				It could be a number of things: Short of refrigerant, excess refrigerant, control issue, clogged heat exchanger, incorrect refrigerant, moisture, air or non-condensibles to name a few.
Why did they change the valve? Was it the expansion valve? Has it got the original refrigerant & oil types in it? Other than this issue & the frozen coil, have you had any other problems?
Car A/C is not my speciality, but frankly I don't trust garages to even know the condenser from the evaporator. I'd take it to a refrigeration/Air con. technician or a vehicle A/C specialist.
