Results 1 to 10 of 21
Thread: D1, starts immediately, won’t idle more than few secs or rev
    Sep 2009
    tasmania
    Well as the title suggests, that’s what’s happening. Got a D1 with a 4.6 running 14cux. Have just put it all back together with a thor manifold, started within the first quarter of a revolution. Thought you beauty, that’s another job done. alas, not to be. The bugger just won’t idle for more than a few seconds. Using all of the 14cux sensors ie stepper/tps/fuel temp/water temp etc etc and 3.9 fuel rail.
    It has injected gas and it’s hard to say whether it runs on that or not, it switched over and ran but cut out after a few seconds – out of gas. I seem to vaguely remember (geez, it was only earlier today) I could rev it.
    So it was leading me to the petrol side. had a set of newly reconditioned yellow top injectors in with this change (never had them in before) so pulled them out this arvo and put the old green tops back in. nup, same issue.
    checked the timing with a timing light which was fine, well it should be it starts easily. Whilst it idles for a few seconds I dash around to the exhaust to have a whiff, no petrol smell which I would have thought there would be.
    I have a set of lambda indicators in the dash and when the car starts I can see them hover around lambda then as the car slowly begins to die I can see the mixture getting weaker and weaker. Revving it just makes it die instantly. I also have the software for the lpg and can see injector opening times. At startup petrol are ok then as it starts to die I can see the injectors opening up more but the engine still konks out. So it’s trying to compensate for the decreasing revs by upping the injector time but no go.
    So I am starting to think petrol supply. turn the key to ignition and prime the petrol pump and hold down the schraeder valve at the same time and sure enough it’s a boy. Plenty of petrol gushing out. If I prime it then depress the schraeder valve immediately once stopped priming it still gushes out as it releases the pressure. However if I increase this period to say 5 seconds after priming and then depress the schraeder valve the pressure is all but gone and no fuel comes out.
    So I am starting to think pressure regulator or not sure if there is meant to be a oneway valve at the fuel pump end. Something is letting the pressure release quickly and maybe also not allowing the pressure in the fuel rail to get to the correct pressure for the injectors to discharge fuel correctly.
    If I had a pressure gauge I’d put it on the schraeder valve but even then how do you determine it’s the pump not able to get up to pressure or the regulator is not able to hold any pressure? Maybe clamp off the return line or will this damage the fuel pump? Or is this one of those things you’ve just got to replace the part (regulator) to know for sure?
    Anyways, had enough thinking about it today. Time to go and walk the dogs.
    (the fuel rail etc had been apart for the last 4 months with no fuel in it, maybe some rubber seal in the regulator has dried out and lost its ability to seal? 4 months is not that old for fuel i would have thought to make the car perform like this?)
    appreciate any suggestions.
    thanks,
    brett.
    sounds like youve lost the signal from the coil to the computer thats turning on the fuel flow.
    Avoca Beach
    The wire is attached to the MAF loom. have a look see.
    Regards Philip A
    Crafers West South Australia
    A test light wired to your pump circuit will tell you how long it runs for. In a pinch you can hot wire it, just bridge terminals 30 and 87 at the fuel pump relay.
    If you don't find a wiring fault, try disconnecting the vac hose to the fuel pressure regulator. If the regulator is stuffed it may be holding just a bit of pressure.
    Sep 2009
    tasmania
    Checked the fuel pump was running whilst car was idling. Just depressed schraeder valve and she was still coming out. Even hotwired fuel pump off relay as a double double check but no change in symptoms. Ran without vacuum connected to regulator but no change either. As much as I was hoping for a spare wire to plug onto the coil there isn’t one unfortunately. When car was laid up had it running on an rpi dual timing power amp but I’ve swapped between that and the standard ign module enough times in the past to be comfortable that the wires are in the right positions.
    I noticed this morning that there was no tacho signal and the battery charge light is on. They weren’t on when I was checking yesterday during the day as I made a point to ensure they were working (can’t speak for the afternoon didn’t check them then). thought might have knocked wire off back of alternator but they’re still there. I thought tach signal came from coil +ve ( or was it negative), either way those two wires are still connected to the coil.
    Any more places to look or sounding like pressure regulator and the alternator charge/tacho is separate issue?
    Mud wasps nesting in your air flow meter? Try unplugging it, should run albeit roughly.
    Sep 2009
    tasmania
    thanks bee utey. yeah i've tried most of the obvious things. unplugged them etc as i know the 14cux will pick up some default values. done same to tps too. the bXXch just won't change her behaviour. they're all like that eh? (said in jest)
    i'm going to swing by allan at british 4wd and pick up a regulator anyways as i feel the pressure should stay in the rail longer than a few seconds.
    darwin
    no nothing about fuel injection,is there enough battery power to run the fuel pump,
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Quote Originally Posted by pibby View Post
    OK maybe the mud wasps (serious!) have nested in a fuel pipe. Disconnect the fuel line at the filter, check for flow/pressure from the pump. Run a hose into a tin. Blow back the lines to the filter using compressed air.
    Sep 2009
    tasmania
    bee utey - have used the schraeder valve to check for fuel many times in the past. the amount of flow coming out now is the same as has been in the past. what is different now is the pressure disappearing so quickly. and bugger, the shop is not open this morning though normally is saturdays so couldn't get fuel regulator.
    any other ideas out there? what if i clamp off the return line or restrict it almost completely to replicate the restriction of the regulator? would this potentially cause damage to the fuel pump?
