Results 1 to 10 of 12
Thread: Vin # and plastic head dowels
    Ean Austral Guest
    Gday All,
    I remember reading a thread where someone posted the vin # where they changed the head dowels on the TD5 from plastic-to-steel.
    Does anyone remember the thread or have the numbers im talking about...
    Dad has a 2004 model D2a and has been told at he's next service.160k he should get the head done just incase the head has moved..
    If someone can point me to it or has them would really apprieciate it.
    Thanks and Cheers Ean
    Jun 2008
    McMinns Lagoon NT
    Here Ean, was looking at it last night!
    This one slipped through!!!
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Ean Austral Guest
    Thanks Stuuu,
    after reading all that it seems that overheating is still the killer..
    I know that hasn't happened to Dads so will try and convince him not to stress...Am sure he will start get some warning before the gasket goes..
    Cheers Ean
    Its actually quite common, several years seem to have the plastic dowels.
    There is no - reliable - vin range..
    Dec 2010
    Brisbane Bayside
    Everyone LR mechanic I speak to tells me that after 03 they have steel.
    Aug 2009
    I was under the assumption that the plastic dowels were only there to help guide the head back onto the engine block ... it's the bolts that hold the head in place.
    Happy to be corrected?
    May 2003
    On The Road
    True enough,,
    but if the bolts come loose the head movement soon wears through the plastic---
    True enough,,
    So the underlying problem is just that, not the plastic dowels.
    Maybe a periodic torque check of the headbolts, or even replacement would have been a better idea in the service schedule.
    May 2003
    On The Road
    Is there any reason this is not done?
    is it detrimental to the gasket?
    Ean Austral Guest
    Am sure I read somewhere that the head bolts cannot be re used or re tightened...This always never made sense to me, but just assumed they were some type of bolt that may have been heat affected by the different metals they went thru/into..
    Surely even if you replaced them 1 by 1 then its got to be a better option than the head gasket failing..
    Something for someone who is not far from changing a head gasket to try..Makes sense to my small brain..
    Cheers Ean
