24th January 2011, 09:55 PM
Transfer case front output bearing
Hey Guys,
I currently have a terrible noise coming from my front output bearing. This horrendous noise and oil leaking profusely makes me believe that the bearing and seal are cactus.
The answer i seek is whether or not the bearing can be replaced in-situ or does the whole case need to come out?
Towards the other end of the car have any of you done a rubber donut to uni conversion and had dramas with leaking pinion seals? Since doing my conversion a bit over a year ago i have done 3 pinion seals and a bearing.
Any help would be appreciated.
Steve
24th January 2011, 10:07 PM
Yes the seal and bearing can be replaced insitu on a LT230 TCase.
What sort of lift do you have under the wagon?
I wonder if there would be some value in balancing your shafts or checking for some other "vibe" issue. That sort of failure rate seems a little excessive.
S
24th January 2011, 10:20 PM
Cheers for that.
It now has a 40mm OME lift but that has only gone in after the first 2 seals.
I am looking at getting the tail-shaft re-balanced to see if this helps. It is a rebuilt rangie shaft that i got as part of a conversion kit so i am assuming it was balanced then but i dont see it hurting having it done again.
Could vibration from unevenly worn tires do it?
Steve
26th January 2011, 07:38 PM
#4
My experience with the T-box output seals is fit genuine ones only and make sure 100% the faces where the seals sits have no damage / nicks at all!!
27th January 2011, 01:24 PM
#5
Thanks UP
I will definitely have a good look around when i have it apart.
Steve
