If you have a ute and still want a ute, you can't go past a 130 dual cab. they are big, great for work and play, but if you feel too big, then consider a 110.
CRABs (Child Restraint Anchor Bars) are not standard in defenders so you will need to get one made up and certified by an engineer. this may add about $500-$700 to the price, but is worth it. I bought my 130 with one already fitted...
If you think series, then I think you may not like electrics? if this is the case, 1998 was the last year 300tdi's were made (I think) and there is significantly less electrics than the Td5.
No matter what, there will always be people here that will tell you a 300Tdi is better than a Td5 and vice versa... personally, I think you would probably pick up a 300Tdi cheaper than a Td5 and thus be able to spend more coin on accesories! 20-25K should get you a real gem either way.
In any case, good luck and I look forward to the photos!
					 of owning a series vehicle, any 110/130 prior to '98 would be a viable option.
					 'Horse has bolted' and all that....
 = 2 happy parents!
 = 2 happy parents!
