Results 1 to 10 of 11
Thread: Galv strips
    Galv strips
    Hi
    Is there a way to tidy up the dull looking gal strips on the series?
    I'm positive I saw a thread on it not that long ago and I can not find it.
    I did a google search also but all it appears to give me is ways to clean it so it can be painted or prepped to be galvanized.
    When I paint the car I would like to tidy all the gal strips up so they dont look old and dull
    is there a way?
    Feb 2010
    Supine
    Steel soap pads...works the best. (With thanks to Uncle Ho.)
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I have used a cutting polish on them. Other suggestions include steel wool, pot scourers, and mild acids such as vinegar. But I think my idea removes the minimum amount of zinc, and helps to preserve the surface better than most methods.
    Northern Midlands, Tasmania
    Regular rubbing with bare hands. Check out the local playground bars.
    Feb 2010
    Supine
    Quote Originally Posted by korg20000bc View Post
    That's a lot of rubbing
    Some people are better rubbers than others.
    Dec 2009
    Queensland (though occasionally elsewhere)
    I've just recently used a brass-coated wire brush on mine, and it came up beautifully. I guess the message from people will be to use the most gentle means you can, to leave the most of the original surface as possible. No doubt somebody has a better method than mine.
    Lostkiwi Guest
    Hi
    is there a way?
    Is this the thread you were looking for?
    http://www.aulro.com/afvb/series-2-2...tub-parts.html
    possibly was thanks
    Oct 2010
    Hi
    So will you change your handle from "dullbird" to "shinybird" if you "tidy up the dull looking gal strips..."?
