D5000 doesn't have commander mode so your out of luck there.
Yongnuo have e-ttl triggers.. Not sure if they have a made one for nikon yet.
If you doing it out doors, wireless triggers might be the better solution as you might find the flashes can have some difficulty talking to each other outside, especially if your using modifiers as they tend to block the signals.
SB-900 is the way to go.. or SB-800 if you happen to find one cheap. SB-700 would also be worth a look though I think its pretty much the same cost as a SB-900 atm.
SU-800 is a commander only and costs about as much as an SB-600.
If your not too far from a power point I would be considering a monolight, more power, and you should be able to get a Softbox too for the same cost as a SB-900 and SB-600
edit. High speed sync is something too look for too. So you can still have the shallow DOF
					 I wouldn't look at a second hand flash unless you are really sure of it's history.  Flash units eventually burn out.
