What engine do you have???
If a TD4, the lift pump in the tank (near the tank) can play up. While expensive I do not believe it is any where near as expensive as you have indicated. The main high pressure pump for the common rail is very reliable and is unlikely to be an issue.
If a V6 then I have no idea.
garry
