Thread: air con fault code 21/22 sunlight sensor
    Northern Beaches Sydney NSW
    hi all,
    today of all days my air conditioner in the D2 packed up. the fan is not blowing any air at all, the air cond is clicks on/off but there is no air blowing out the vents. i did a manual check with the lcd screen (auto + direction switch) then switched car on. error code fc 21 & 22 which is the sunlight solar sensor on top of the dash. just happened to have another and swapped the head around but no differences. 3 wires connect to the sensor not sure where they go to. fuses seem all ok. checked fuses under driver side dash and under bonnet (d/s) are there more fuses elsewhere. code states 'open or short circuit, no solar heating connection' what does this mean many thanks for any help
    Williams West Aust
    Sunlight sensor will show a fault if you dont do the test in full sun.
    Was a recent post with the same issue,burnt fan motor was the issue.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    FC 00
    re did the test this morning and a new code appeared fc 00, sunlight sensor was in full sun, need to chase this code down now. thx
    Perth W.A.
    Did that code prove to be nothing all good I believe?
    Jul 2014
    west of Transylvania
    00-no faults logged
    11-in car temp sensor fault
    12-ambient temp fault
    13-thermister fault
    14-heater coolant temp sensor fault
    21-sunlight sensor left side fault
    22-sunlight sensor right side fault
    31-left hand temp control servo fault
    32-right hand temp control servo fault
    33-air distribution servo motot fault
