Diesel in a 101
					Like many 101 owners I have thought off and on about converting my 101 to a diesel.
The 3.5 petrol is not exactly a powerhouse and motoring in a 101 is a leisurely affair at 90 kph with fuel consumption between 10 and 14 mpg.  It also runs well on LPG when further than a few 100km from major cities is not obtainable so ULP gets a bit expensive - where gas is available in remote locations it is often as expensive as ULP.
So what diesels would you consider putting into a 101.  Noting that the front suspension is sensitive to weight increases over the front axle and that without extensive modification to the radiator mountings the engine would have to be a max of about 4 cylinders long - straight 6 cylinder diesels would most likely be too long.
Given the costs of conversion there would need to be an improvement in onroad performance so that easy cruising at 110kph would be possible.  The LT95 transfer case would have to stay (to operate the winch) but it would be possible to graft another gearbox (short one) to the cut off LT95 transfer case.
The obvious conversions are a 200tdi or 300tdi but from what I gather performance is even more leisurely than the petrol but fuel consumption is good.
A TD5 with a chip would provide the required oomph but might be a bit squeesy length wise.  I assume that the electronics could be modified with a bit of patience.
The Izusu 3.9 is old school and a bit low on power and revs but does have good torque - however it is really too heavy for the front end.
Chev 6.2/.5 V8 diesels do not have a good reliability reputation and again for the hassle of doing the mods the engines are old school and down on power but have good torque.
The Mazda 3500 has been fitted and runs OK just a little down on power.
What about the modern jap diesels like the Triton 3.2 DID - nice power and fuel consumption.
You can get D3/RRS 2.7 TDV6 diesels in the UK for about $5000 and even TDV8s (exchange  ) for about $7000.
) for about $7000.
For me the TDV6 diesel would be ideal if the electronics could be sorted.
So, 101 owners, you know your vehicles - if you were to change to a diesel what engine would you go for and why??
