Thread: Rope Oil Seals
    Rope Oil Seals
    The rear main oil seal on a Jag V12 engine is a rope seal which are prone to drying out when not used. My engine has not been used for quite a while and I am concerned what when I do start the engine the friction of the crankshaft turning will burn the seal.
    For those with knowledge of such things is there anyway I can prepare the seal for use after being idle for a while.
    I thought that filling the sump with cheap thin oil and lifting the front of the engine so that the seal would be covered with the oil may allow it to soak up enough oil to protect it. Obviously before start - draining this oil and replacing with the correct grade and amount.
    East-South-East Girt-By-Sea
    1.20 MB
    What about using an oil additive like Nulon "Long Term Engine Treatment" Long Term Engine Treatment - Nulon Products Australia it is recomended for protecting engines on cold start ups.
    Thanks - might be Ok once the engine is operational again but not sure it will help in my current case as I need to get the rope "oiled" up before I turn the engine over and it fires.
    Crafers West South Australia
    Most engines you can access the back of the flywheel from below. It should be possible to spray some penetrating lube (chain lube?) up there from underneath, while rotating the crank by hand. Maybe you need to fabricate a nozzle from fine brass tubing like used by model steam engine builders.
    remove the oil pressure sender and using a small pump prime the engine through there.
    A facet pump setup to draw the oil out of the dipstick hole with the right fittings to fit the sender will work nicely let it run for about 5 minutes prior to turning the engine by hand then on the starter. If this is going to be a regular requirement consider putting a T piece with both a shut off valve and blanking cap in the oil pressure sender fitting with the oil pressure gauge plumbed in on the other side.
    then
    hook up and Start the pump let it run for a few minutes.
    Crank the engine over on the starter till the oil pressure gauge registers pressure.
    remove the pump and blank off its port on the T piece
    start the engine.
