Results 1 to 6 of 6
Thread: D3 Compressor failure !
    Rockylizard Guest
    Gday...
    Today I received the message - "Suspension Failure. Only normal suspension height available" ... together with the amber warning light for suspension.
    Was near the dealer so dropped it in for a check and the advice was compressor and relay failure ... needs to be replaced ... not in stock so gotta get it in (3-4 days wait) ... cost around $1,000 plus fitting - probably $1,200 all up.
    The D3 has 89,205km on the clock .. so I am a little disappointed
    Is this a fairly typical life cycle for a compressor?
    My other query to the forum is whether "someone" reconditions compressors and if so, I just might keep the 're-conned' one for a spare.
    Open to all advice.
    Yass NSW
    some info here http://www.aulro.com/afvb/d3-d4-rrs/...r-failure.html
    I've not tried the compressor that I repaired but it seems to work OK on the bench.
    Regards,
    Tote
    Mar 2010
    Perth, WA
    Asked the same thing a while back
    http://www.aulro.com/afvb/d3-d4-rrs/...placement.html
    I still have the fault but haven't been off road so haven't needed to fix it yet....will be interested in responses.....
    Darren
    NSW SW Slopes
    My D4 one stopped producing pressure at about 35K. However there was a problem from new, always taking far too long to raise the front of the vehicle. I'll see if the slow raising front is fixed when a new compressor is fitted.
    I have an 09 D3 and the compressor failed after 18k kms. Luckily it was replaced under warranty. I was told that it would cost $1200 to replace if outside warranty. They should last approx 3 years depending on usage.
    Sydney, Australia
    You can try cleaning out or replacing the dryer before getting a new one.
